Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
Thread: Injector data...its ALL what its cracked up to be!
  1. #61
    Junior Member ASNUPHIL's Avatar
    Jul 2012
    Greg,
    well done for pointing this out, so many people do not think about the fluid and the changes in it's make up that occur when you are flowing injectors straight from an engine, the fuel will contaminate the testing fluid, by how much and how soon depends on the amount of use the system gets and it's especially important if you are carrying out OE comparison testing.
    Of course, in the factory the injectors are new and their is no contamination of the test fluid, but where the testing guys like yourself are doing, it's very difficult to ensure all the gasoline has been removed from the injectors unless you ultrasonically clean them prior to testing, which would be my recommendation.
    As you rightly pointed out, Heptane is expensive, so using the ASNU Flow Rite is a cheaper option, but as you have said, experience now shows you that you will now need to clean the system and replace the fluid and ensure all the injectors are as good ASNU before testing them.
    For those doing non oe comparison testing, like normal injector testing and servicing, the fluid is ok as your main aim is to ensure all the injectors are performing the same.
    A very valid comment and one that everyone carrying out oe comparison testing or characterisation of injectors must take into consideration and ensure they maintain correct fluid specifications.
    Phil.
  2. #62
    Hi Greg,
    Your pic shows the mass flow has changed (does that indicate the density of your test fluid has changed with age (why did it change...?)...?), but what about the volume flow...?
  3. #63
    Apr 2009
    Good question, Joe. I actually took volumetric measurements in the burettes. Mass flow was calculated from volume, so what you see is a change in volumetric flow, which was converted to mass flow. I did not weigh the fluid directly, so I'm not honestly sure how much the specific gravity has changed over time. All I really know is "the fluid has changed with age".
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
  1. Replies: 42
    Last Post: June 16th, 2015, 08:30 AM
  2. Converting Ford style injector data to data useful to EFI Live.
    By JOHNBOY in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2012, 05:19 AM
  3. 96# injector data?
    By BLK02WS6 in forum Gen III V8 Specific
    Last Post: July 2nd, 2011, 07:28 AM
  4. Injector Data
    Last Post: November 24th, 2009, 06:07 AM
  5. I cracked the 96 lb injector idle AFR!!!! Now it wont idle!
    Last Post: October 13th, 2005, 11:09 AM
