Results 1 to 10 of 10
Thread: Need hypertech/efi cant do
    Member JST's Avatar
    Jul 2007
    Default Need hypertech/efi cant do
    How do you set the speed on this truck,I have reset the ECM/TCM no help,he has 285/75/16 and is 5 mph off ? Have EFI ?
    __________________
    2002 GMC 2500HD 4x4 SCLB STOCK MOTOR WITH TOMAN TUNING,FASS 150, M/A TRANS,11.90 ON A GOOD DAY IT'S MY WORK TRUCK,19 TO 21 MPG WITH ME DRIVING,THE TRUCK (OLD RED )HAS 909,000 MILE AND LOVING IT,285/75/16
    Apr 2008
    messure the accual tire size (height) and enter that
    285 should equall about 33 but have seen some as low as 31.5 inch tall
    stock sucks
    Member JST's Avatar
    Jul 2007
    Put in 37" still 5 mph off ?
    Aug 2010
    Quote Originally Posted by JST View Post
    The speedometer is 5 MPH off at what speed - 50 , 100, etc. ? Speedometer error is a percentage not a constant.
    Post the original (not modified) ECM and TCM tunes, as well the tire manufacturer and model line (i.e. Goodyear manufacturer - RSA model tire - etc.) for the 285/75-16 tires.
    Myself or another Forum member will take a look at it for you ..
    Regards,
    Taz
    Member JST's Avatar
    Jul 2007
    5 mph at 70 and 3 mph at 35
    Member JST's Avatar
    Jul 2007
    RUSS ROBERTS.tun RUSS ROBERTS TRANS STOCK.tun Had 245/75/16 and now 285/75/16
    Aug 2010
    The ECM tune you posted has had the Speedometer parameters altered - need an unaltered stock version. Also need the tire manufacturer and model for the new 285/75-16 tires - to then look up precise tire data. Once I have these pieces to the puzzle, I will try and help out.
    Getting late here - probably won't check the Forum again until Monday.
    Regards,
    Taz
    Member JST's Avatar
    Jul 2007
    BFG tires,I have tuned 126 trucks to date and set the speedo on 80 % of the trucks,I check it with my GPS after setting it,if you look on the forums a lot of trucks can not get the speedo set with EFI (newer gas trucks) I did reset the H0136 from 370 to 333 no help,2 gas trucks in the area had a tech 2 set it after thay gave up with EFI.
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Try these.
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
    Member JST's Avatar
    Jul 2007
    Quote Originally Posted by Rhino79 View Post
    Try these.
    Thank you,let you know
  1. EFI RWHP and EFI RWTQ
    By dbaxter_ss in forum Tips and tricks
    Last Post: July 26th, 2010, 03:43 AM
  2. Hypertech damage? What should I do?
    By jonnyk in forum Gen III V8 Specific
    Last Post: November 30th, 2009, 02:54 PM
  3. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 02:25 PM
  4. Efi Live wrote and now hypertech is screwed
    By rzuff in forum Gen III V8 Specific
    Last Post: June 22nd, 2007, 04:14 AM
  5. reading hypertech flash
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 16th, 2007, 09:33 PM
