Finally have the truck back together after 9 months. I reinstalled EFILive to the latest versions and updated the V2 firmware. I can read/write OK, read and clear DTCs, but if I try to log an error report is generated.....typically $02 or $03 Edit: Never mind the scanning issue............the scanner was defaulted to "stream fast"
Also, I read the PCM and the VIN does not match my actual VIN or last saved tune which are the same. The only other thing that seems to have changed was that the MAF fail parameters went back to stock (this is an SD tune). Not sure how the VIN could have changed on its own. According to the VIN it was for a full size 1500 truck, 4 DR, with a L59, 2.4L L4 engine!
