Before I start I'll just say what I'm about to write is the culmination of my conclusions derived from searches on the web. Feed back and corrections are most welcome.
Tuning - using Efilive & WB O2s, and EGT and CHT
I’ve been searching on Google and on other forums, and there doesn't seem to be many people taking this route? I bought Efilive so that I could learn to tune on the road but never felt I quite got there. I’ve had varying degrees of success dialling in the MAF and VE map, non-conventional route (both together), getting my LTFTs nice and tight, but never felt happy with the feedback from the engine for tuning spark advance.
From what Ive read EGT's sometimes get written off as a tool because they have been used to dial in fuelling without much success (carburettors), maybe from before when WB's weren't so readily available? the stigma holds it seems. Monitoring CHT & EGT for the tuning is standard practice with aircraft engines, and CHT tuning appears to be popular in the carting world, lack of dyno facilities I suppose led to necessity.
So I'm away working with time to mull over the timing feed back problem when i came across an interesting article id seen before, attached.
"Effects of Ignition Timing, Equivalence Ratio and Compression Ratio on RDH Engine Performance"
The research on a spark ignited engine amongst other things demonstrated the effects of the above on IMEP, PICP, ISFC and EGT.
EGT reduces as IMEP increases to its maximum, or the Knock limit. However EGT alone can not pin point peak IMEP.
So further searching looking at EGT sensors drew my attention to CHT sensors and what CHT can tell you, like your AFR is tuned to maximum flame front speed, and timing at minimum for MBT, less time for heat transfer to the cylinder head.
So here goes, I wont to try and put together a 101 for tuning with Efi flash scan, WB O2, EGT and CHT. - Continued next post
