Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Tuning - using efilive & WB O2s, and EGT and CHT
  1. #11
    Feb 2007
    I did some more logs repeating the above, re calibrated my LC-1's just to be sure, included fuel consumption liters per hour. Logs attached.
  2. #12
    Gelf, thanks for the update.
  3. #13
    So throughout the range of timing, idle speed was 800+/-75 rpm (I notice the variance gets smaller as timing increases)... is this where your cam likes to idle...?
  4. #14
    Oct 2011
    i got 800f for egt's at idle. seems high.
    My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
  5. #15
    Feb 2007
    Correct, for the analysis I set minimum idle air to 0 g/sec so that the PCM wouldn't interfere, spark correction tables were zeroed out, idle spark, HI, LO and coast down spark to the same values, starting at 50 reducing down to 10 in 0.5 degree decrements, I logged a minute (~600 frames) of data at each 0.5 degree and allowed PCM to hold desired idle at 800rpm using the throttle only (bi directional controls only allow maximum of 10 degrees retard from final timing so I did it over four logs)
    Idle min max range is observed to tightest around 38~42 degrees timing, idle was smooth
  6. #16
    Feb 2007
    Quote Originally Posted by wyochimneysweep View Post
    What is your idle timing, 800f = 427C, that would be around 20* timing on my set up
  7. #17
    Oct 2011
    my idle timing is around 22-24 at 800 rpm. got 18in-hg at that setting. is that to hot or should i not worry
  8. #18
    Feb 2007
    I wouldn't worry, what AFR? where is your sensor located, my EGT sensors are located in the headers about 2" from the head.
  9. #19
    Oct 2011
    lambda hovers at .98-1.01 and sensors are in the headers within two inches of the heads. one on number 5 and the other on number 6
  1. Do these O2s look bad too you?
    By bigblock69 in forum Gen III V8 Specific
    Last Post: June 5th, 2012, 01:18 PM
  2. STFT Swings and Narrow O2s
    By Highlander in forum Gen III V8 Specific
    Last Post: August 18th, 2009, 06:56 PM
  3. reading Problem ( LC-1 logwork & gage & EFIlive )
    By Ls1_Rulz in forum FlashScan V2
    Last Post: October 17th, 2008, 06:42 AM
  4. which pids for ve tuning w o2s
    By ssmike300 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2008, 11:52 PM
  5. Tuning without o2s question
    By tuff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2005, 03:12 PM
