Seems the only internal problem with fittting a 06 LS2 or LS7 into a 97>2005 is that the reluctor is 58 tooth vs everything else being 24. The sensors are a wiring fix but isn't there a way to "hack" the 2x reluctor using our Flashscan?
The alternative is to tear the engine apart and change the wheel.
