Results 1 to 3 of 3
Thread: HELP.02 lb7 no start after converting to dsp5
    New Member jmac's Avatar
    Aug 2009
    Default HELP.02 lb7 no start after converting to dsp5
    I was tuning(attempting) a buddy's truck. 02 chevy.(15186006 OS)I was using a proven script from a reputable tuner on here.I have used it many times with no Issues.Its a dsp 5 tune
    Everything went just like it was supposed to.I did the full flash,everything went just like normal.When it was done I noticed a clicking.Turned key off waited the 15 secs,turned the key on and the clicking was still there.After a search the clicking was coming from the ign circut breaker,and the glowplug relay and possible 1 other thing in or around the lifter valley.Anyway it crankes but no start.When I try to go back in it says it cannot connect to ecm.Same with the scan tool,it can't hook up.But if you use the test feature before flashing it says its good.But after a few secs it comes up that it lost communication.I'm out of ideas.I disconnected the battery's for 20 min,then retried with no change.Its setting with them disconnected now.
    Here is the stock tune.The stock tune after converted to dsp5.I can email or pm the script file,or tuned dsp5 if need be.What can be done to get this going again?
    It had a banks setup with speedloader on before(if it matters)But was removed correctly.It also has the ppe high idle switch.(if that matters)
    03 X cab longbed.K&N cold air kit,4" turbo back stright pipe exhaust. Was PPE,Now EFILive.(if I'm smart enough to use it)
    Jan 2006
    It sounds like you have tried about everything, and are still unable to communicate. If you want to send us your ECM, we will evaluate it on the bench for you, no cost.
    Quote Originally Posted by jmac View Post
    Custom Tuning Services
    Aug 2009
    Quote Originally Posted by killerbee View Post
    Thank you for the offer.I hope I don't have to take you up on it.
    I found this old thread,and I'm hoping its the same thing.I'm getting ready to remove the switch.We put the switch in prior to anything else and it ran fine.Then after the full flash,all the clicking relays happened.
    http://forum.efilive.com/showthread....light=no+start
  1. LB7 DSP5 Harsh Defuel Ghost
    By xploitdiesel in forum Diesel
    Last Post: February 22nd, 2014, 03:37 AM
  2. Lb7 dsp5 defuel problem help?
    By DMAXTIM in forum Duramax LB7
    Last Post: July 14th, 2011, 02:21 PM
  3. ? Converting dsp5 back to single tune
    By boccheballs in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 29th, 2010, 09:22 AM
  4. Converting existing tunes to dsp5?
    By Pruzinsky14 in forum Duramax LLY
    Last Post: July 26th, 2009, 03:01 AM
  5. LB7/LLY DSP5 V2 update
    By GMPX in forum General (Diesel)
    Last Post: September 28th, 2008, 11:37 AM
