How much of a role does boost level play into rattle? I have tuned most of the 'rattle' out via reducing a couple degrees of main timing and fine tuning via pilot time reduction. Now I still have a hint under low boost conditions initially when hammering on it. I have a open volute turbine (hence the need for my question, not slow spool, but could be better) and will be changed swapped for a divided housing soon. But theory in tuning timing with regards to boost is what I'm interested in, not the solution to my hardware situation. I hope you don't mind Rich, but I dug a quote out of my notes where you were speaking on the topic. I am quoting this to hopefully get this thread started and if anyone wants to jump in and enlighten on anything, please do!
"It's a combination of timing advance, engine load, fuel qty and boost.
Obviously if the timing is advanced, you're going to dramatically increase cylinder pressure.
Compound that with getting on the throttle (adding fuel), with little or no boost and you're simply generating to much cylinder pressure....timing over advance."
So..under low boost conditions there is a lack of _______ to ________ that causes high cylinder pressure that produces the 'rattle' sound. Obviously rattle can be fundamentally broken down into timing to early trying to force the piston back down on the upstroke. But there are A LOT of variables (as Rich also touched on in his original postings) that dictates the sweet spot..not to mention the whole other can of worms...pilot injection. If the conversion should stray to variables other than boost itself..that's okay too. More information the better.
