Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: flash pinouts
    Feb 2016
    Does anyone happen to have the E92? Im wondering if it is the same as the E39.
    Also I am looking for the E55, and E83 Diagrams if anyone is able to help.
    Aug 2010
    You can purchase 3 days of access to all GM manuals for $20, from the ACDelco website.
    Sign up on a Friday - order in pizza all weekend - and download as many schematics as you would like.
    Feb 2016
    I have access to diagrams through alldata, Im still having trouble getting a couple to communicate
    I havent tried the e83, e92 or e39 yet. I have worked on the e55 as well as another Cadillac controller that I dont know the exact controller designation.
    I am having trouble getting the e55 and the other Cadillac controller to communicate. I read somewhere that the low speed serial bus in the Cadi controllers wakes up the ecm to allow high speed data. I messed with them last weekend and got nothing out of either of them.
    Guess I will just have to keep messing with them. EFI Connection must have figured it out because they sell a harness for the e55.
    Aug 2010
    Are you trying to build harnesses to bench read / flash controllers ?
    Feb 2016
    Yes, I have the pinouts from the computer. hooked up ground, 12v power, ignition voltages and CAN but couldnt get anything out of them. Only ones so far that have given me this much trouble.
    Aug 2010
    For the price EFI Connection charges (Speartech's prices are higher) for their bench harnesses - doing it yourself is not really cost saving - if you factor in materials and all of the time spent.
    Just my 2 cents ...
    If you have the power (battery and ignition), ground, and CAN High and Low wired correctly, then perhaps you have omitted the Accessory Wakeup input (wire this to 12 volt ignition).
    Feb 2016
    I included it also but cant seem to get it to do a darn thing. I will try again. Maybe im overlooking something.
    Feb 2016
    Went back through everything today and still nothing.
    I have attached the pinouts of the one I am working on. Anyone see anything I am missing?
    I have......
    Connector 1
    1- CAN
    2- CAN
    17 - Switched 12v
    18 - Switched 12v
    19 - Switched 12v
    20 - 12v Battery
    46 - switched 12v
    Connector 2
    73 - Ground
ID:	19323   Click image for larger version.
ID:	19324   Click image for larger version.
ID:	19325   Click image for larger version.
  9. #19
    Mar 2009
    Download station info E78= J1-19=battery pos
    J1-20=battery pos
    J1-43=can low
    J1-29=can high
    J2-13=switched 12v+
    J2-28=switched 12v+
    J2-73= gnd
    WORKED FOR ME THANKS
  1. E40 Pinouts
    By JimmyJazz in forum General
    Last Post: September 1st, 2010, 07:28 PM
  2. E38 Pinouts
    By Tre-Cool in forum E37, E38 & E67 PFI ECM's
    Last Post: June 18th, 2009, 10:51 AM
  3. E38 PCM Pinouts
    By vxchev8 in forum Gen IV V8 Specific
    Last Post: March 2nd, 2009, 09:28 PM
  4. E38 Pinouts
    By Harrismarine in forum E37, E38 & E67 PFI ECM's
    Last Post: October 27th, 2008, 07:53 AM
  5. LS1 ECM Pinouts
    By Cougar281 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2007, 02:36 PM
