Results 1 to 10 of 19
Thread: flash pinouts
    Jul 2008
    Default flash pinouts
    the bench harness tutorial is a bit outdated at this point. does anyone have E78 and E83 flash pinouts?
    TIA
    You will need to look at a wiring schematic for each of E78 and E83 powered vehicles (of which I don't have).
    Jul 2008
    neither do i.
    What year/model/vehicles are your ECM's from...?
    Jul 2008
    i have a new E76. i have no E83 yet.
    Aug 2010
    GM Service Manuals or DVD - absolutely indispensable, and worth the cost in the long run.
    Regards,
    Taz
    May 2010
    Vector, send me a pm I have access to what you need and then some.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    May 2010
    I have also been looking at the pcm flash pinouts for the newest ecms, and if I get some free time would like to help update that tutorial.
    I think Paul has the originals of the pin-out documents (I hope so, because I don't).
    I'll send him the details for the E39, E78 & E83. I think that should cover all the missing ones.
    Mar 2009
    Download station info E78= J1-19=battery pos
    J1-20=battery pos
    J1-43=can low
    J1-29=can high
    J2-13=switched 12v+
    J2-28=switched 12v+
    J2-73= gnd
    E39= J1-20= gnd
    J1-30=gnd
    J1-39=can high
    J1-40=can low
    J1-51=switched 12+
    J1-52=battery pos
    J1-71=switched 12+
    J1-73=switched 12+ Note all pins are in J1 so we don't have the added cost of J2
    be sure to use a power supply rated for at least 3 amps as the e39 pulls a lot of current
    E78 is the same as the mt-88, Entrol 88
    we also put an led on the fuel pump relay pin to see if the cal is valid
    Questions? give me a call Steve 909 910 3867
  1. E40 Pinouts
    By JimmyJazz in forum General
    Last Post: September 1st, 2010, 07:28 PM
  2. E38 Pinouts
    By Tre-Cool in forum E37, E38 & E67 PFI ECM's
    Last Post: June 18th, 2009, 10:51 AM
  3. E38 PCM Pinouts
    By vxchev8 in forum Gen IV V8 Specific
    Last Post: March 2nd, 2009, 09:28 PM
  4. E38 Pinouts
    By Harrismarine in forum E37, E38 & E67 PFI ECM's
    Last Post: October 27th, 2008, 07:53 AM
  5. LS1 ECM Pinouts
    By Cougar281 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2007, 02:36 PM
