Results 11 to 20 of 33
Thread: Help with Cruze tune....
    The DMA PID's should be ok, are they reading wrong or can't you select any of them?
    Re the top end knock you are seeing, I'm not sure what the best fuel is in NZ, so you may have to back it off a bit. Out here with our 98 Octane only a few degrees of timing is tolerated which is about what that tune should be commanding. One thing I've noticed, it would appear the timing figure you see in the scantool does not take in to account knock retard
    Oct 2006
    I can select and log them but they are all reading 0.0 expect the octane scaler which appears to be flat line at 0.031, Would you like to see a log file?
    Its running 98 but our fuel is pretty poor (in keeping with us being your poor cousins) im getting around 6 deg with this tune at WOT so need to lower it but would like to log APCYL-DMA so i cant work out where im at in the spark table.
    Oct 2006
    If I log 2 or less DMA pids only I get error code "ERR_IGNORED/4" if i log 3 or more it will log but no data....
    Oct 2006
    Ok so I have got the PIDS all working thanks Ross, but now have a few more issues, I am getting random throttle reduction during full throttle dyno pulls, it looks like torque reduction and lasts for around .5 sec with the throttle reducing to 50%, it can happen around both peak torque and peak power but that may just be coincidence, has any one seen this before?
    I am also struggling with top end power, so far we have a big gain in low down torque but once we get to around 5000rpm it hits a wall and the power drops back to standard even with boost around 18psi 2deg timing and 11.8 afr. It feels very surge and flat above 5k, On some dyno pulls it shows a big dip in power and torque curves reminiscent of LS1 valve springs, do these have issues with valve springs or exhaust flow? We have removed air filter and left the intake lid up which did not help..
    Any ideas? It’s looking really promising with the low down torque but I just can’t get past the other two issues, I have seen other peoples dyno graphs online and they have no issues with top end power so what am I missing?
    Quote Originally Posted by rally1 View Post
    Only time I see throttle reduction is on a 1-2 shift, if the wheels slip a little then it will hold the throttle at 50% until I lift.
    Word is they might
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    I Know this is an old thread, but I came across it while researching tuning Cruzes. I'm looking to buy one and want to see what I can do with them. Are they flex fuel tune able, or did you just retune for E85 all the time? E85 is something I would very much like to be able to run. I run it in my turbo truck all the time, but Have to retune every time I switch fuels. Is that what you have to do with the Cruze too?
    Dec 2006
    8.7 @ 84 (1/8 mile) bolt-ons
    Sep 2005
    Guess i should have looked a little harder, lol. I did buy a 2012 Cruze yesterday, so looks like its time to start playing!
  9. #19
    Dec 2006
    Congrats, and have fun!
  10. #20
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    I've spent the morning tinkering with the new .calz release on a customers Cruze. This thing wakes up big time below 5K, but after 5K RPM it's like it want's to go take a nap.
    My logs show the electronic throttle closing from 85% to %52 over the course of a few hundred RPM starting at about 4900RPM. At first I thought it was KR related, because I had a consistent 1.9KR from about 5K up. Then I figured out how to get rid of the mysterious 1.9KR using table B1940. My desired TQ command is a constant 190 Across the board at WOT and I'm not getting any detectable knock. Anyone have any idea why the car is closing the throttle on me?
    Nick
Name:	Cruze problems.jpg
  1. Cruze 0 to 60 results
    By GMPX in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: July 20th, 2012, 12:45 AM
  2. Flexible fuel Cruze/Sonic?
    By engimuneer in forum E78, E83, E84 PFI ECM's
    Last Post: April 26th, 2012, 10:02 AM
  3. Cruze questions (1.4 trans and 1.8 tune)
    By Boost in forum E78, E83, E84 PFI ECM's
    Last Post: August 17th, 2011, 04:21 AM
  4. turbo Cruze first thoughts
    Last Post: August 16th, 2011, 01:50 PM
