Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: What PID to scan commanded afr & injector duty cycle for e78
    May 2010
    Default What PID to scan commanded afr & injector duty cycle for e78
    What PID to scan commanded afr & injector duty cycle for e78 ?
    EFILive Tuner
    Start by trying IBPW1/2 and INJDC1/2... those may or may not work for E78.
    May 2010
    I Tryed both
    its not working they are giving higher values more than 100% even in e38 i havr the same problem
    And what about commanded afr ?
    EFILive Tuner
    Try GM.INJPWB1/2.
    May 2010
    Joe i tried those also they are not valid in E38
    I need to log the duty cycle urgently because I'm going to tune FI car
    EFILive Tuner
    For E38 there is a set of pids named E38.xxxx (same with E67), I'll have to look at which ones are the correct ones...
    in the meantime, can you find which injector pulsewidth pid gives sane values (e.g. 2ms at idle and under 20ms at 6000 rpm).
    May 2010
    The pids for pulse width are GM.INJPWb1 and GM.INJPWB2
    EFILive Tuner
    Are there any calc pids using those...? If not we can create a pair.
    May 2010
    Joe I don't know if there is any
    Can you help me create the needed pids ?
    EFILive Tuner
    Ok, give me a day or two...
  1. Injector Duty Cycle & PIDS Frustrations!!
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: September 5th, 2011, 04:19 PM
  2. Injector pulse width & duty cycle
    By etmotorsports in forum Gen III V8 Specific
    Last Post: November 11th, 2010, 03:53 PM
  3. Injector PW & Duty Cycle
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 03:39 PM
  4. Injector Duty Cycle ?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2006, 04:12 AM
