V2 - BBF is failing - Trying to read a tune that I can still read and flash in passthru mode in 7.5
Tried this several times now- latest V8 software. Current BootBlock and Firmware in V2. Formatted the V2 Config folder. Selected the LS1-B for Tune and Scan in the EFILive Scan and Tune software - Programmed this with the (Programmed ALL Required Data) - successfully.
In truck, F2- F1- F1.....Wait ten seconds....hangs on "TRYING MFG KEY".......... Fourth orange light on the V2 blinks every now and then until I get frustrated and unplug the unit and reset the controller.
Scan will work correctly with the V2- Tune is failing.
Ideas?
