Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: LC1 Issues
    Default LC1 Issues
    So i finally got around to putting my new S475 Turbo on and unwired my LC1 from under my truck and rewired it under the hood so the Sensor would be in the downpipe.
    Fired it up and went for the first boosted test drive. wideband worked for about 2-3 minutes then went to 7.5afr.. i can restart the truck and it works for about a minute..
    Yall got any ideas? I redid the ground wires to be safe. Still no worky.
    My new LC1 will be here today, but id love to get this one working so i can put it in the Samurai so i can tune the 4.8..
    Any ideas?
    Apr 2008
    how close is the sensor to youre turbo ?
    it maybe already cooked due to heat
    stock sucks
    prolly 16"
    Same as what KBRacing96 does on all his turbo kits.
    Got my new LC1 in yesterday.. need a Serial to usb adapter now.. argh!!!!!
    Gonna look at goin serial to the V2..
    Quote Originally Posted by nonnieselman View Post
    See post #3 here: serial-port-cable-that-goes-to-v2
    Thanks joe,
    i tried that already and it didnt work.. so i figured id just buy a setup from taquickness.
    I got the new LC1 in and finally found a Serial/USB and got it programmed.. why the heck do they still use Serial connections? Thats 20yr old technology :(
    Now i have a wiring issue, the LC1 and gauges come on and go off when they want to.
    ( lol, actually serial comms dates back to the 1960's... 50 year old technology )
    Sounds like a bad power/ground connection.
    I knew it was old.. heck i studied that crap and computer programming in college almost 10 years ago..
    I gotta run some more wire in my rats nest of wires under the dash..
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Well im having trouble with my LC-1. The gauge reads fine that I have attached to it... But the flash and scan box isnt getting any information.
    I've driven a little it and logged at least twice and just all the sudden nothing couple starts latter.. not getting anything.
    I checked the Flash and Scan box and it says that there is no wide band connected. I tried recalibrating the heater and the sensor. Thinking that would help but Im still getting nothing when logging.
    Quote Originally Posted by HellKnightHicks View Post
    Are you using serial comms, check your serial cable and the RJ12 plug on the end of it...
    also make sure that the null terminator plug (looks like a blank 2.5mm stereo plug) has not come unplugged.
  1. v2 with LC1?
    By Nver2loud in forum Gen III V8 Specific
    Last Post: June 7th, 2014, 02:48 AM
  2. LC1 to V2
    By ALRAJHI in forum FlashScan V2 BB Logging
    Last Post: November 2nd, 2008, 09:44 AM
  3. LC1 and Gauge issues...
    By nonnieselman in forum Lounge
    Last Post: September 14th, 2008, 01:02 PM
  4. Lc1,e-85 ?
    By Lextech in forum General (Petrol, Gas, Ethanol)
    Last Post: May 16th, 2008, 03:05 AM
  5. V2 and LC1
    By LSs1Power in forum FlashScan V2
    Last Post: January 3rd, 2007, 08:56 AM
