your sposed to plug that in the other side?
I ordered one of those cables that goes from the 3.5 mm to the Rj12 "phone jack". I checked both ends of that.
if the 3.5 terminator is needed why did it ever work?
It says in the LC-1 user manual to use the terminator plug... I could not get mine to do serial comms without the terminator.
Odd it worked.... ill have to shove that in there.... im just really suprised that it worked in the first place...
Thanks for the tip ill check back.
Added the terminator and still the flash and scan reports that there's nothing connected.
Even checked the settings pertaining to the wide band and the com port on the Flash and scan.
It has worked but no longer does.
Can you connect to your LC-1 using the LM Programmer software on the laptop/PC (need the straight thru cable from Innovate to do this)...?
I have the cable from innovate but i dunno what i did with that software disk.
The LM Programmer software can be downloaded from Innovate's website
( in general, do not use discs that come in the box, they are usually out of date )
Log works software?
Found at the top of this page.
http://www.innovatemotorsports.com/support.php
Thats what i need right?
Downloaded log works onto my laptop... waiting for the usb to serial adapter to come in... should be her tomarrow. Then well find out for sure whats going on.
