I hate it when a new PC/Laptop doesn't have a serial port...
Seriously, automotive needs to get with the program, it is almost impossible to find a off the shelf device with a serial port, come into the 21th century it will not hurt you.
2006 Trailblazer
Well just got around to Hooking up the serial cable to the LC-1
And there software cant talk to it either... I have some screen shots i can post monday...
Should i contact Innovate about the issue....?
Bummer I think i wanna go ahead and hook it up analog so that i can get dial the engine in a bit... I really wanna get to driving this thing befor winter kicks in.....
How do i hook this thing up Analog to my Flash and scan?
Tried to hook it up analog and you have to be able to connect to the system with com port... Thats not going to work... Ordered annother one and will replace shortly.
THanks for the help will keep you posted
The V2 has internal settings for serial WBO2 that need to be set for each manufacturer.
LC-1 WBO2
Flash and scan set for Innovate WO2 on com port
Data type: AFR & Lambda
Bank: Set to both
I think something broke because HKH said it was previously working...
if he can't connect from laptop (LM Programmer software) to LC-1 using the Innovate cable (SERIAL OUT) and the blank terminator plug (SERIAL IN), then either the cable is broken or the LC-1 is broken...
this is the conclusion he came to and is getting a replacement.
