Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Need a manual tune file for E38 - Doing a conversion from 6L80E to TH400
    Jun 2011
    Default Need a manual tune file for E38 - Doing a conversion from 6L80E to TH400
    Hey guys,
    I have a 2010 VE Series II SS-V.
    I am taking out the 6L80E and putting in a TH400, but apparently I need to change the E38 to a "manual tune file".....
    Can anyone help out with this? Let me know what other details might be needed.
    Andrew
    Jun 2011
    Oct 2006
    Try www.tunefiledepot.com web site they have most files. if not PM me and I will send one...
    Oct 2006
    Why are you fitting a 400? I would guess for drag racing or big power? you may have some idle issues unless you have a good sized convertor.
    the only one i have is a 2010 SS Ute manual if this help's
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Jun 2011
    Quote Originally Posted by rally1 View Post
    Yeah, putting some decent power through it...and yes, I do drag race the car. 2800 TCE converter....nothing wrong with the E38 tune and it idles perfectly
    Oct 2006
    You may have some small issues when you try and run a manual tune with an auto, things can get out of whack when you go from park to drive, with an auto tune the ECU knows it has happened and different idle learns etc are used, without the gear selector input during gear selections there could be a few stumbles.
    I have never put a 400 behind an E38 but have done a few LS1-400 combos and it takes a bit to get right if you have a low stall and big cam..
    Did you get a tune? I have plenty if you need one, and remember to make sure the two calibrations are compatible before you full flash or you may end up with a paper weight...
    Lifetime Member JezzaB's Avatar
    Nov 2006
    The tune side is easy. Its the rest of the car that needs the work since alot of modules from the dash cluster to the EBCM need to be reprogrammed. Plus if you dont change to a manual look and jumping the CAN lines etc. Fun fun fun
    Jun 2011
    TH400 is in....engine runs fine, gears change verrrrrrry nicely!
    The only real issue...is that the speedo doesn't work!
    Jez - is this what you mean about the dash cluster to EBCM needing to be reprogrammed? The revs show up fine though...
    Jun 2011
    Hey guys,
    My speedo is still not working.... I've attached the file, so any ideas/thoughts/input would be great....
    E38 - 24092012.tun
  1. How to switch from 4l60e to a manual TH400 - 2003 corvette
    By Tracyrr in forum Gen III V8 Specific
    Last Post: August 18th, 2011, 07:59 AM
  2. I need an stock E38 Manual trans Vette file!
    By Boostin99SS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 9th, 2011, 07:25 AM
  3. Conversion of Auto to manual.
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 18th, 2009, 09:58 AM
  4. E38 Manual tune, anyone?
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: May 9th, 2008, 11:43 PM
  5. camaro auto to manual conversion
    Last Post: March 26th, 2007, 12:15 AM
