Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: My AutoVE questions
    Junior Member mys10v8's Avatar
    Sep 2009
    Default My AutoVE questions
    I am on my second iteration of AutoVE logging and have a few questions:
    1) The BEN transition filter included with the scan tool includes a 2500 RPM limit - Why?
    2) Can/Should I modify the 400 rpm row in my Main VE table to better match the curve the 800 rpm row is creating?
    3) I am thinking I should hook up my 3500lb boat trailer to get better coverage in the logs. Any comments/concerns about this?
    4) Any of you experts think I am missing anything in the logs? - see any issues?
    Hardware: 99 S10 2WD pickup, LS1/A4/MAF/TB from 2000 Z28, LS1B, FAST intake, TPIS cam/springs (specs attached), shorty headers, 2.5" dual exhaust
    Software: OS from Silverado modified to run LS1 - IFR/transmission/MAF calibrations from Camaro OS
    Truck Cam Specs from TPIS.pdf
    99 S10 LS1 A4 (12212156)_0010 Original Tune.tun
    autoVE_0001.efi
    autoVE_0002b.efi
    99 S10 LS1 A4 (12212156)_0010 SDAutoVE_0002.tun
    I am a long time reader and first time poster - thanks to all the experts who take the time to contribute to this forum.
    --Joe
    Last edited by mys10v8; August 10th, 2012 at 02:34 AM. Reason: transition (not transient)
    Hi Joe,
    welcome to the forum
    1) delete the 2500 rpm line;
    2) yes (the VE table should not contain any sudden hard steps);
    3) loading the engine allows better cell hit counts, dragging the brakes helps (for a short time), IDK about hauling a boat trailer (how fast can you go);
    4) I'll have to view your files later today...
    --Joe
    Sep 2009
    Default More logging
    To continue the story: Ran through iterations/logs of AutoVE. I have attached them all.
    autoVE_0003.efi
    autoVE_BBL_0003a.efi
    autoVE_BBL_0003b.efi
    autoVE_BBL_0003c.efi
    autoVE_0003d.efi
    All these logs were combined with the weighted average xls from here:
    http://forum.efilive.com/showthread....ging-log-files
    When copying into xls I did NOT filter low count cells hoping the summation of all the log files would get me a few more cells with counts > 50. The transient filter was applied before copying into xls.
    Does my WBO2AFR1 jump around more than 'normal'?
    Sep 2009
    Default Tune files
    These are the tune files I created from above posted logs. One w/just the logs applied, another was manually smoothed.
    99 S10 LS1 A4 (12212156)_0010 SDAutoVE_0003b all logs.tun
    99 S10 LS1 A4 (12212156)_0010 SDAutoVE_0003c all logs smoothed.tun
    By the looks of other VE tables I've seen around here this should be smother than it is.
    What do I do with the cells I did not cover in the logs but bumped by 15% as per the AutoVE tutorial?
    Sep 2009
    Default Logging, round 0004
    This log (and the autoVE_0003d.efi above) was with the boat attached - my rolling chassis dyno - made it easier to hold the BEN in each cell.
    autoVE_0004.efi
    99 S10 LS1 A4 (12212156)_0010 SDAutoVE_0004.tun
    This is what is loaded into the truck now (new Main VE and SD):
    99 S10 LS1 A4 (12212156)_0010.tun
    A couple short logs of LTFT with new tune - they are looking quite negative:
    autoVE_BBL_0004b.efi
    autoVE_BBL_0004c.efi
    So what's the effect of just updating the Main VE and not setting it for SD as per Tutorial (C2901, C2903, C6002, B5914)?
    Quote Originally Posted by mys10v8 View Post
    autoVE_0003.efi
    autoVE_0003d.efi
    That spreadsheet is interesting...
    I prefer to take a 20 minute log covering my operating range, and immediately apply this, and to then re-log on this new tune...
    ( the scantool/tunetool human interface is designed to make this easy )
    Your smoothed VE is good as it stands, there is no need to make it any smoother.
    It seems that 15% is too large for the initial bump... study the trend that AutoVE is applying, and manually apply this to the non-hit cells.
    autoVE_0004.efi
    You tuned mostly the low RPM potion of the VE table, and the 4c log shows trims going negative as you get into the upper RPM's...
    also, you have to set the scantool to automatically look for DTC's... we want to see if the MAF failed (which indicates that the PCM is using the VE table exclusively)... if the MAF is not failed (no MAF DTC) then the PCM is still using the MAF or it calculates MAF values from the VE table.
    If you don't fail the MAF, then the PCM uses the MAF most of the time (always above 4000 rpm and during steady state air/throttle conditions under 4000 rpm (B0120)), so modifying the VE table has no effect.
    More comments:
    set B3608, B3609 to zero (permanently).
    set B3615, B3616 to 65% below 3200 and 35% above 3200 (permanently).
    set B3618 to EQR 1.165 (AFR 12.6) regardless of tutorial (permanently).
    set C6001 P0101-3 to A:1-Trip or C:Non-Emissions, make sure one of those DTC's triggers (whenever running SD).
    is FPR manifold-referenced or un-referenced...? If FPR is manifold-referenced then the sloped IFR is incorrect.
  1. AutoVE questions
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: June 24th, 2011, 04:33 AM
  2. AutoVE Questions
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2007, 11:06 PM
  3. AutoVE Issues/Questions
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2007, 04:10 PM
  4. LL8 I6 AutoVE questions
    By blandmiller in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2006, 10:49 AM
  5. AutoVE - 3 questions I need help with
    By Learning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 16th, 2006, 09:40 AM
