Post some pics...
99 S10 2WD pickup, LS1/A4/MAF/TB from 2000 Z28, LS1B, FAST intake, TPIS cam/springs, shorty headers, 2.5" dual exhaust
Started w/OS from Silverado modified to run LS1 - IFR/transmission/MAF calibrations from Camaro OS, 13.974@102.85mph (no traction)
I always hook to a trailer for tuning.. it helps a ton with a turbo..
Hooked to the car hauler and loaded up a Z71 tahoe and i can pull thru the rpms slowly but at full load..
Canyon at 95kPa: smooth down the VE table from 90kPa and up (flatten area surrounding canyon to eliminate canyon), save/flash it, and take another log.
I'm callin' it my rollin' dyno:
It's amazing how many times you guys say that and how many times it gets read but then it doesn't get checked. Thanks for repeating it again. Would be nice if tool put up a big ugly stop sign to prevent that. It's a little more obvious in V8 Scan and Tune - the graphic goes red.
2 Logs taken (applied first log/re-flashed and logged again)
autoVE_0009.efi
autoVE_0010.efi
Tune before above logs:
99 S10 LS1 A4 (12212156)_0010 SDAutoVE_0008c smoothed.tun
Tune after above logs:
99 S10 LS1 A4 (12212156)_0010 SDAutoVE_0010.tun
This is a diff of the Main VE between the most recent tune file and the stock Main VE table (2002 Camaro).
1) If you stare at the above logs and tune file diffs long enough it looks like some values are getting lifted in the lower RPMs and may have lost some in the upper RPMs. This is what this cam is supposed to do. And, the areas that are still +~6% (from the tutorial bump) should probably be ratcheted down some more.
2) Look at the 2 cells highlighted in this diff @2800RPM and 90&95 kPa. In the last log they had counts of 150 and 99, respectively. Their values create a spike in the VE. Do I just push it back down or maybe I should stop over analyzing?
1) push those plateau areas down a little (you say ~6%) and roughly smooth (fill in holes, lop off spikes);
2) lop off those spikes;
take another log and post.
How is your drievability and throttle response (in OLSD) at the moment...?
