Results 1 to 4 of 4
Thread: LS1 with a 4L60E swap with shifting problems,
    May 2008
    Default LS1 with a 4L60E swap with shifting problems,
    I have a Jeep cj7 that i originally installed an LS1 from a 2000 ws6 trans am in with a TH350 behind it and when the TH went bad I decided to upgrade to a
    4L60E I also used PSI conversions wiring harness for the 6speed manual and when I did the swap I talked with PSI and had them send me a harness to add to the manual trans harness to add the wiring for the trans control.
    With all that said here what the problem is. when I got the trans in and the wiring and ready to drive, the trans does not shift down or up on its own, it never shifts to OD and no lockup, If I take off in Drive, it stays in drive, it nevers shifts down or up, I have a ratchet shifter and I can shift it down manually to second and I do have reverse but thats it. I have speed signal from the VSS and it is calibrated accuratly. If I can figure out how to take a screen shot of my efi live I will because I have all sorts of transmission codes, also I have 13.5 volts supplied to the trans and have verified that. I used a schematic that I downloaded and has been accurate for everything else so far and I checked the location of the pins that I installed for the trans harness 3 times, so I'm fairly sure that they are correct. I am wondering if the tune I used from the the Tune File Depot is correct? I downloaded a 2000 camaro tune for the 4L60E.
    I have also talked to Novak where I purchased the trans and they did not know what to do, they said that trans worked when we shipped it out, I dont think that is where the problem is anyway, but it will move under its own power and its like its only shifted manually.
    SOOO.....anybody have any ideas? Thanks.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    May 2008
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    I think something might be wrong in the harness and/or PCM connector.
    May 2008
    Yeah I'm thinking that too. So whose got a pdf for a good schematic to use for this part of the wiring? That would be the vest place to start since that's pretty much the only thing I have messed with. Thanks
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  1. Performabuilt Lvl 2 4L60E Not Shifting at Desired Points
    By tatasta in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 16th, 2012, 03:28 PM
  2. Shifting harsh/soft with Speed Density (LS1 PCM)...?
    By joecar in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 29th, 2009, 05:29 AM
  3. LS1 PCM Performance shifting
    By Cougar281 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 02:31 PM
  4. 4L60E to 4L80E swap
    By hquick in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 22nd, 2007, 08:48 PM
  5. 4l60e tranny shifting problems
    By vettenv in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 18th, 2006, 04:39 PM
