Results 1 to 10 of 11
Thread: Unrecognised PCM
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default Unrecognised PCM
    Downloaded a tune from a 2006 VZ 6L Thunder Ute and recieved the following unrecognised PCM error. I am assuming this is a custom HP Tuners cal as car is mafless.
    Can somebody maybe confirm this for me please.
    Will attach pics and tune.
Name:	pcm error.jpg
ID:	13699   Click image for larger version.
Name:	pcm error2.jpg
    Oct 2004
    Not 100% it's an HPT COS, but it definitely isn't an EFILive supported calibration and will require a full-flash to stock OS.
    Andrew
    EFILive Crew
    Nov 2007
    Yeah its a HPT Custom OS.
    yeah its a HPT Custom OS , had one a couple months ago same os number
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    May 2005
    Ok cheers, thanks for the help fella's.
    Apr 2012
    i have a car at the moment that says the same so how can i go about tuning it ? in a 2007 ve e38.
    Nov 2007
    You need to flash a stock OS over it. I dont think the OS that the other guys and the OP has was used in 2007 VE. If you post what you read out of it someone can probably tell you what the stock OS number would be
    Apr 2012
    ok ill have a look for the OS next time i see the car
    just was not sure if i have to get a new ecu or write over it
    Apr 2012
    so i had a look at the car and the OS is
    OS. 01250210
    cal ID. 12612380
    BCC. YPRZ
    is that enough info for someone to help me out.
    i have the same year car so can i full flash my tune onto his E38 and just update the VIN ?
    12612381 is the OS you will need to flash in to that VE.
  1. Unrecognised ECM (HELP)
    By 02402RAMAIR in forum Gen IV V8 Specific
    Last Post: January 30th, 2009, 05:37 AM
  2. Unrecognised PCM
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 9th, 2007, 07:34 AM
  3. 2 more Unrecognised ECM's
    By 02gmcwaldoch in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: May 17th, 2007, 11:16 PM
