Results 1 to 10 of 19
Thread: Too small of a supercharger after dyno results
    Sep 2008
    Default Too small of a supercharger after dyno results
    http://img42.imageshack.us/img42/968...ddzjoiptls.mp4Well did a dyno day to get the tune corrected(we did as the wide band shows a good flat A/F ratio) but the results did not end well.
    436 wheel horse power and the supercharger was maxed out @ 4200RPM.
    Vortech V1 with a 7" crank pulley and a 2.75" on the blower.
    forged internally balanced Chevy 383(5.7 rods),15cc dished pistons, 76cc heads (large valves & ported runners),Holley stealth ram,duel 58mm throttle body,60# injectors,air to water inter-cooled.
    Looks like I cannot get more than 6-7# boost.
    This sucks but I think I am going to go a 88mm turbo now.
    Was expecting more but I am told the V1 is doing what it is made for-600hp.
    Please take a look at the tune and advise if you see a problem that could attribute to the restriction, thanks.
    Dyno July 31st CCMR.tunccmr_wot1.efi
    Jan 2012
    Something is off. MY procharger with a 4" pulley makes 6psi at 5100 rpm and has much more to go. Im limited by my injectors so I cant go higher. I would do a boost leak test and see if your losing boost.
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    That makes no sense.... I would look for leaks first as well.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jan 2012
    do you have any pics of the dual throttle body set up? also, with such a small pully, are you getting any belt slip?
    Dec 2008
    Quote Originally Posted by andysc3 View Post
    Probably this:
    http://www.holley.com/112-503.asp
    Sep 2008
    Great news!! It was a boost leak. Corrected it and now I see the gauge just peak past 10# but run out of road tonight.
    Fast, pulls hard all through 2nd then into 3rd but no road to continue. Will need to contact my dyno guy and redo.
    I will post some picks. Weird thing though, when launching from a stop, when it gets to the top of 1st, seems to putt and die(that's when I let off) but if I kick down, it does not do it?
ID:	13713   Click image for larger version.
    Sep 2008
    more
ID:	13715   Click image for larger version.
    Sep 2008
    Still, I am thinking I should upgrade to a V7 YSI for real power.
    May 2012
    Sweet setup! Glad u found the leak Post dyno results on the redo pls
    Interesting setup, and with AC too.
    Where was the leak...?
  1. Dyno Results
    By TexasCummins in forum Cummins 5.9L
    Last Post: November 7th, 2011, 08:08 AM
  2. First Dyno Tune... Thoughts, Results, Etc.
    By 2010TestCar in forum Gen IV V8 Specific
    Last Post: October 13th, 2011, 02:09 PM
  3. New Dyno Results
    By vatman02 in forum Gen III V8 Specific
    Last Post: March 19th, 2008, 06:47 AM
  4. Dyno results
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: November 3rd, 2007, 05:15 PM
