Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Auto VE Tuning Data Filter Question
    Senior Member jeff keyuk's Avatar
    Jun 2008
    Default Auto VE Tuning Data Filter Question
    I have started a autoVE Tuning and would like to know is this the right filter I am using ,My goal is to get my AFR inline ,car is very rich!I have Data logged a few times,and it seems there is very little change each time,Thanks for looking.
    Sep 2008
    Your TP filter parameter - TP not equal to 21% has me concerned - the filter will take out all other TP % cell hits.
    I'd just go with the filter setting advised on Pg 13 of the AutoVE Tutorial (found under Help - tutorial - AutoVE in the scan tool program) in the first instance.
    cheers
    HSV Senator 300 - the Classy C4B...
    C4B - ETP215s 62cc, Comp 215/223 .601/.609 @111+3, Manley 8.050" 5/16" P/R, Morel Link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster chain, OTRCAI, T-56 - RipShift, HydraTrak 3.91:1, DiFilippo 1.75" 4-1s, twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune.
    308rwkW(413rwhp)
    Jeff,
    That filter is incorrect... (somehow your filter got crossed)
    it should read like this:
    Filter control: Include data frames
    {SAE.TP} is changing
    less than 5% per 100ms AND
    {GM.FTC.cell} is not equal to 21 AND
    {SAE.ECT.F} is greater than 176°F AND
    {SAE.RPM} is greater than 500 RPM AND
    {SAE.TP} is greater than or equal to 1%
    Sep 2008
    Jeff / Joe, I posted an example screenshot of an AutoVE map result and a basic filter setting in Jeff's other thread. Hope it helps.
    cheers
    308rwkW(413rwhp)
    Ok thanks macca.
    Jun 2008
    Thanks again joe ! and macca for all your help!
    Jun 2008
    Joe! In the Data Filter, I can not add {GM.FTC.cell} it say it is not valid .And when I go to the pid list,It will not let me add it to my pid list! That is the (Fuel trim cell number),and do I need to apply that to my filter???? If so how do I do it. Cheers
    That means you did not log GM.FTC... so then you can leave FTC out of the filter.
    Jun 2008
    Hi Joe! My B3618 in open loop I set them at 1.00 and B3605 I set them the same as the AutoVE Tutorial,My question is on the {Things to check}Did you want me to set thoses two table to AFR not EQR units.Thanks jeff
    Regardless of the AutoVE tutorial, set B3618 to your target PE/WOT EQR (1.16 for NA), and set the last 2 columns in B3605 to the same value
    ( this does not cause any problems in AutoVE because you will see those values in the pid GM.EQIVRATIO )
    ( last few columns in B3605 in the tutorial is too lean for my liking; problem with B3618 set to 1.00 is that people forget to set it back to rich )
    ( note: if your BARO is less than 100 kPa, then set all the columns in B3605 from (BARO - 5) kPa to 100 kPa to the same value as B3618 )
    I would prefer to use EQR units everywhere.
  1. Data Filter for OL nly in ScanTool
    Last Post: May 17th, 2008, 04:24 AM
  2. COS 5 and Auto VE Tuning Question
    By RacerChris in forum Custom Operating Systems
    Last Post: June 15th, 2007, 03:49 PM
  3. Question on Auto Ve tuning
    By MSGHUFF in forum General (Petrol, Gas, Ethanol)
    Last Post: May 6th, 2006, 05:52 PM
  4. Auto VE tuning question (long)
    By Ira in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 08:38 AM
  5. Filter Question??
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 27th, 2005, 10:13 AM
