Results 1 to 10 of 12
Thread: 08 Sterling Bullet 5500 6.7 Cab and Chassis
    Aug 2012
    Default 08 Sterling Bullet 5500 6.7 Cab and Chassis
    Haven't tuned a cab and chassis, just wondering if I can tune them or not? Have a customer interested. Thanks
    Senior Member KhakiCummins's Avatar
    Sep 2011
    I would assume that since EFI works on the Dodge C&C it would work since they are the same truck just with different badging. I suppose that there could be an OS in the Sterilings that EFI hasn't seen yet though and may need to be added for it to work
    Nov 2005
    Shoot me a VIN and I'll check the OS for you
    Cheers
    Cindy
    Jul 2012
    I just ran across this thread. Is EFI capable on a STERLING BULLET platform?
    Nov 2005
    C&C trucks are supported.
    If you would like PM me your VIN and I'll double check.
    Cheers
    Cindy
    Mar 2011
    i have a read from one and says its not supported
    Joe Kupferschmid
    Daves Diesel Angola
    www.angoladavesdiesel.com
    Diesel and gas tuning
    Personal Vehicles tunes with efi 06LBZ, 05lly, 2002 Z28, 2004 Gto
    Quote Originally Posted by House View Post
    Post the read/tune up so support can look at it and determine if the OS just needs to be mapped.
    Nov 2005
    There are sone very outdated OS's too. Those won't be supported, however once the file is submitted we will determine if that is the case and tell you what the most updated OS is.
    Cheers
    Cindy
    Aug 2013
    I'm also trying to tune a 08 sterling bullet with a cm2100 ecm but it keeps telling me the ecm is unrecognized when I try to open it in V7.5. I'm at a lost, any help would be greatly appreciated.
    Aloha
    Nov 2005
    Have responded in your other thread.
    Cheers
    Cindy
  1. 4500/5500 support
    By cumminsDK in forum Cummins 6.7L
    Last Post: May 21st, 2012, 04:27 PM
  2. Need an LBZ cab and chassis tune
    By THEFERMANATOR in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 8th, 2012, 02:20 PM
  3. 2009 5500 Duramax idle question
    By JustinD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 7th, 2012, 09:08 AM
  4. Silver Bullet Tuning makes 625hp smoke free.
    By 2007 5.9 in forum Cummins 5.9L
    Last Post: December 12th, 2011, 06:12 PM
