Results 1 to 6 of 6
Thread: injector flow rate issues!
Hybrid View
    Feb 2005
    Default injector flow rate issues!
    hi all, im about to change the ifr values using the spreadsheet, i noticed the default are values are very different to the stock ones i have.
    stock values
    28.150200
    28.584234
    29.204282
    30.754404
    31.126433
    31.622471
    31.994501
    32.180515
    32.366530
    32.676554
    32.862568
    33.110588
    33.482617
    33.730636
    34.102665
    34.536699
    34.970733
    default values
    36.4892
    36.7166
    36.9426
    37.1672
    37.3905
    37.6125
    37.8332
    38.0525
    38.2707
    38.4875
    38.7032
    38.9177
    39.1310
    39.3431
    39.5541
    39.7640
    39.9728
    if i use the default values and enter the upgrade values, will this pose a problem?
    The spreadsheet requires you to enter rated flowrate, rate pressure, fuel rail pressure, and it computes the new IFR values, overwriting the defaults; so you can just ignore the defaults.
    Are you using the newer spreadsheet that has a tab labelled "EFILive"...?
    Feb 2005
    whoooops! makes me feel real smart, thanks for the rply iguess if you dont ask you wont know, i though that the default values were there as a base, then all calculations were made from there. thanks for clearing that up mate.
    edit: yes i am using the efilive labelled spreadx sheet
    Feb 2005
    70.8281
    71.2640
    71.6974
    72.1281
    72.5563
    72.9820
    73.4052
    73.8259
    74.2443
    74.6603
    75.0741
    75.4855
    75.8948
    76.3018
    76.7067
    77.1095
    thats the new calc fuel rail press 58psi 62lb injectors r8td @ 45psi
    When you get a chance, post your rated flowrate/pressure, fuel rail pressure and new IFR values so we can look at them.
    Agro,
    Yes, I calculate those same lb/hr values using your numbers.
    Cheers
    Joe
  1. Injector flow rate
    By sinr98 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2010, 04:59 AM
  2. Injector Flow Rate
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2009, 10:22 AM
  3. Injector flow rate
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: March 13th, 2007, 04:33 PM
  4. injector flow rate issues!
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: February 20th, 2006, 09:58 PM
  5. the injector flow rate table..
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2005, 02:17 PM
