Results 1 to 3 of 3
Thread: Different Operating System ?
    Nov 2011
    Default Different Operating System ?
    I want to load a "stock" non-modified tune - I think I found one - but when I tried to load it - it said "different operating system" so checking other buttons/options I see there is one to load tune with different operating system. Since I am totally newbie - I wanted to ask if there are any "gotchas" to this procedure? Will I be able to re-load my current loaded modified tune - after loading a base tune with different operating system number? Thank you in advance.
    If your sure the OS will run the vechicle, your gonna have to do a full Flash?
    And after you do a full flash with the different OS, your old tune file will not reload (i.e. it won't do cal-only flash)...
    you have to manually copy all the tables from your old file to the new file.
  1. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 12:58 PM
  2. Going from 00 to 02 operating system
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 12th, 2007, 04:50 PM
  3. '01 dsp2 operating system?
    By justinc in forum Duramax LB7
    Last Post: February 27th, 2007, 10:33 AM
  4. operating system
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: February 22nd, 2007, 11:49 AM
