Results 1 to 10 of 12
Thread: 2007 Silverado Classic ETC Issue
    Aug 2011
    Default 2007 Silverado Classic ETC Issue
    I built a 5.3 S/C Engine for a customer and everything works well except for one annoying problem.... When in closed loop and below aprox. 2500 RPM the throttle will only open a maximum of 25%. In open loop it works as you would expect opening properly in relation to how far the pedal is pressed. I've looked at the various tables and nothing stands out to me as a place where I can modify this. Any help is appreciated.
    Jim
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Can you post up the tune.
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Are any DTC's being triggered...?
    Aug 2011
    No Trouble codes, truck works great just can't accelerate hard until the rpms are up and the throttle opens completely. More importantly, the customer can't do a burn out..... priorities. Any help is appreciated.
    Lifetime Member Gregs's Avatar
    Sep 2008
    Quote Originally Posted by RdRacerZ28 View Post
    I don't know if this will help you out or not but I maxed out B0401 and B6614 in my tunes. Looks like you already did a good job disabling all the other torque limiting and traction control options.
    -Greg
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Aug 2011
    I maxxed those out Gregs, I'll give it a try........ throttle is also limited to 25% in park/neutral as well. Test driving now.
    Aug 2011
    No change unfortunately..... hopefully someone has run into this before.
    Sep 2008
    Bummer, the only limiting table I see left are the abuse mode ones in the trans but I dont think changing them will fix your problem.
    Oh! I just remembered you might need to tweek the airflow model table for the etc. i'm away from my computer right now so I cant remember exactly which table it is. I'll put my money that you're having more airflow than is modeled in the stock table and the computer is trying to prevent a "runaway" engine. ...yep that sounds right to me.
    Hopefully someone will chime in and remember what table you need to modify
    -Greg
    Stock for now
    Jun 2005
    Here you go - made some changes for your problem. Also, you had several out of range values - I fixed those. However, your injector flow rate table is WAY jacked up! Where did you come up with that? Are you still working the VE table? it needs some work...
    GM EFI Tuner
    Aug 2011
    Quote Originally Posted by BLK02WS6 View Post
    I'll give it a try, didn't know anyone had posted. The Injector table does need some work, someone was in there before me. We dynoed the engine and made sure the WOT and heaver load areas were good now I'm cleaning up the rest in the chassis dyno and the road.
    Thanks for the help.
  1. 2007 classic 6.0 litler for economy
    By robertsteele in forum Tuning For Economy
    Last Post: July 26th, 2011, 02:19 PM
  2. Replies: 8
    Last Post: August 13th, 2010, 04:54 PM
  3. 2007 Silverado E38 speed limiter
    By BLK02WS6 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2010, 12:47 AM
  4. Late 2007 - Early 2008 Silverado 6.0 SD Tune Question
    By Mike Norris in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 07:57 PM
  5. 2007 Colorado IL5 PCM Read Issue
    By CGTMS in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 12th, 2008, 11:48 AM
