Results 1 to 8 of 8
Thread: Cruise not working properly after tire calibration
    Lifetime Member Max Power's Avatar
    Nov 2005
    Default Cruise not working properly after tire calibration
    I tuned an 08 LMM and at the same time I corrected for his tire size as the speedo was off about 10%. I thought everything was ok but when he took it home he noticed that it down shifted really easily on a small hill. When he brought it back I test drove it and it definitely isn't right. After fooling around with several aspects of the tune I finally figured out that it was the speedo change that is effecting it. It seems like the cruise is seeing too much speed loss for some reason.
    Resume is also terrible. IF you set the cruise at 60mph and slow down to 30mph and hit resume it will speed up, down shift, up shift, down shift, etc.
    Either I am overlooking something or something was perhaps overlooked by EFI Live?
    09 LMM Duramax
    Nov 2005
    Incidentally, I talked to another guy that has tuning on his LMM and he is experiencing the same problem.
    09 LMM Duramax
    Dec 2009
    make that x3 here. I never made the association with my tire recalc; I always thought the CC was just crappy, lol.
    Jul 2012
    this help any?
    http://forum.efilive.com/showthread....-and-tire-size
    and if I remember reading correctly there is 3 tables that must be updated, the regular, tow/haul and cruise table. I'm not familiar with the terms to know the B#### those would be.
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Don't have the answer Tony, but maybe some reasoning. Shift changes are conducted according to the complex schedule that are more simply based on a pedalposition/RPM/speed combination. With cruise on, this must rely on a different "virtual" pedal position input (pedal does not move). If the truck is not reacting quickly enough the cruise fueling control will continue to rise. I do recall that in many vehicles there is a table to limit the max rise to cap the fueling. Perhaps that has something to do with it. Hope that helps for something.
    Custom Tuning Services
    Lifetime Member LB72004's Avatar
    Dec 2011
    how about {B0852}
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Dec 2009
    I don't see B0852 on the LMM
    2008 LMM
    Dec 2011
    i guess you are right. it seems to be in all of the earlier models but not the LMM
  1. Cruise not working after calibration flash....two vehicles
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: November 3rd, 2016, 09:22 AM
  2. 08 LMM 4X4 tire calculation not working
    By DVR IMP in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2011, 03:08 PM
  3. External flashscan inputs (EXT.AD1 & EXT.AD2) are not working properly!
    By TransAm-Z in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2011, 08:25 AM
  4. LMM cruise not working
    Last Post: February 1st, 2010, 04:02 PM
  5. Lean cruise patch working for 2003 A4 Vette OS 12221588
    By Treurentner in forum Tuning For Economy
    Last Post: October 22nd, 2008, 04:28 AM
