IS the P12 supported for autocal and if not ETA??????
Yes, read and calibration flash are supported.
I tried to load files last night, which worked, although when I was trying to program the autocal with the BBx software, the P12 was supported on scan but not flash? I BELIEVE i have the most current software???
Do you have firmware 2.07.35 installed on your V2...?
Did you do Program All of the BBx config into your V2...?
i do not see a program all as an option... i check the p12 box under scan, but there is no p12 pid available in tune?????
I am opening scan and tune v8, then bbx, highlight scan, then p12. I then highlight tune, then there is all other PCM options BUT the p12...
Is there a tutorial on how to set these up or i am i just that retarded?
V8 Scan & Tune
goto BBx
on each of Scan and Tune edit the pid/ecm lists, delete items not for your ECM; add items for your ECM;
click Save (to file)
click downarrow next to Program, click Program All.
now i cant get the files to load, I have the p12 format in the autocal, but when i load files into explorer and drag them into the bottom (they are saved as files for remote flashing) nothing appears on the autocal when i scroll through. when i drag the files down they take 20 secs or so to "load"???
