Results 1 to 10 of 20
Thread: 3rd Gear TCC locking/unlocking issue
    Member 1BadAction's Avatar
    Mar 2009
    Default 3rd Gear TCC locking/unlocking issue
    I have my trans tune very close to where I want it, holds 3rd with TCC locked up to 47mph then shifts to OD/Locked. The issue comes in at 3rd gear in traffic when I let off the gas, the TCC unlocks, then locks back up again when I put my foot back on the gas. PWM has been hydraulically eliminated and the TC is a 3200 Circle D, so it gets annoying, not to mention the excess wear this causes. I want it to stay locked when I am at 0% throttle and the TCC lockup tables reflect this, am I missing something else that causes it to unlock? Vehicle is a 2003 4.8L GMC Sierra.
    2013 1SS/1LE Blue Ray Metallic Camaro - DD
    1991 2500 Suburban - Roller cam'd high compression 454ci BBC tow monster
    1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
    1984 18' Contender Tunnel/2.4 Merc ModVP
    Mar 2009
    Tune, if anyone wants to take a look.
    GMC 4.8L_8-12-12.ctz
    If the tune file originated from a truck then it will do that...
    the car tunes kept the TCC locked on zero throttle (F-car and Y-car).
    Mar 2009
    Any way that I can fix it?
    Can you seg swap a car trans segment? The only way that this can be fixed is to run a car TCM OS/trans seg, works really well though!
    You will need a car trans segment from a file with the same OS as your file...
    Mar 2009
    Doesn't appear that I will be able to make it work. OS 12579405
    You would have to do something like this:
    change your OS to 12212156 from a Camaro/Firebird (auto trans), and manually copy all your tables over.
    The problem with that is that its an 03, not an 02 so its DBW and a 1MB PCM not 512kb PCM.
    Ah... so then it's not doable... ( I failed to see the small detail, sorry )
    (I have no idea if the GTO keeps the TCC locked on zero throttle, let alone a matching OS id).
  1. 3rd gear flare shift
    By mstordahl in forum Cummins 5.9L
    Last Post: June 5th, 2012, 08:05 AM
  2. 3rd gear t/c lockup
    By whackem04 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 27th, 2011, 10:38 AM
  3. converter locking in 2nd & 3rd @ WOT
    By Superado in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2009, 08:27 AM
  4. locking/unlocking issues
    Last Post: July 13th, 2009, 12:32 PM
  5. Locking and unlocking converter in 3rd gear
    By Scott(382-$T$) in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 29th, 2006, 04:25 PM
