Results 1 to 10 of 10
Thread: help with base tune 6.7L
    Member O1Z06's Avatar
    Jan 2011
    Default help with base tune 6.8L
    I finally got to crank my new 6.8 (it only took a year) and I am looking for some tips that might help steer me in the right direction. I think there are only two sensors in their original location, everything else has either moved or is a new sensor. I think the largest changes were the ZR1 MAP, LS2 90mm TB, ID1000cc Bosch Inj MAP referenced and 1L displacement increase. All of these have been taken into account based on either manufacturer supplied data or data I found here.
    Any ballpark startup air and base airflow #'s? I am modifying most of my data from a base tune 6.0L LS1B silverado and my old COS5 Z06 tune. Startup was super rich (to the point I was pegging the WB and smelling unburnt fuel). I used the spreadsheet to calc startup VE, increased startup air, increased startup AFR (these were seriously rich) and increased base airflow.
    It will now crank for about 3 second and fire at which point I have to hold a steady 12% GM.APP to it to swing around 1100 to 1300 rpm. Main VE seems to be close so I'm not really worried about that yet. As soon as I let off it will die.
    Does the LS2 tb require any other changes than B4349 0.0191?
    2001 Z06 512K Road Runner COS5
    LSx 427, Comp 7075 TT in progress
    Jan 2011
    It will now hold a steady idle. What made the main difference was B4349 going the other way 133%. So i set 0.0330 and reset the desired air up 18% from my old engine tune. It was starting to be ridiculous to add 40g/s desired air. I have attached my tune and log I just ran if you wouldn't mind taking a look.
    Cranking still is a long way from good because I have to bump the accelerator and eventually it starts.
    3rd idle long start surging89.efi
    COS_02020005_3Bar_SD_idle_AutoVE_0089.tun
    Jan 2011
    I finally got a nice startup and idle but now I'm not sure what is going on. Please see attached log at frame 5789. What is telling the idle to go to 0 degrees? Throttle response is not good as you could guess. Also IACDES_B g/s hangs so I am guessing TF?
    Any help is appreciated.
    good idle cold start bad hot start throttle response90.efi
    Jan 2011
    Everything is running great in idle, but I have found what could likely be the reason for my low tip in throttle timing and hard warm start. P0343! All my timing tables are a good 10* advance above what is being commanded.
    The P0343 should be an easy fix but what burns me is I check the pins when the engine was out. I guess I'm human and just goofed on this one. I hope the fix works.
    Quote Originally Posted by O1Z06 View Post
    Increasing B4349 to 0.0340 [%/mm^2]
    this is telling the PCM that the throttle area now maps to a larger TP... I'm thinking this over (trying to wrap it in my mind).
    I'm looking at it but I don't see the reason, I'm curious to know why...
    Is your CMP sensor/relector located at the front or rear of the cam...?
    Jan 2011
    I am almost 100% sure that it is burst knock. I haven't flashed the new tune yet but will let you know soon.
    Cam has provisions on the rear but the block is an LS3 so I have to use the front cover sensor. The problem was the A&C pins reversed somewhere either in the extension harness or the short factory harness.
    Jan 2011
    Joecar, have a look at this post: http://forum.efilive.com/showthread....ull=1#post8011
    AH, yes, I do remember reading that a while back, thanks.
  1. ls6 base tune
    By evilperformance in forum Gen III V8 Specific
    Last Post: June 28th, 2012, 12:16 PM
  2. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  3. anyone have a base tune for mangacharger?
    By blackc5ls1 in forum Gen III V8 Specific
    Last Post: August 27th, 2009, 09:00 AM
  4. Need a base tune
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: August 15th, 2009, 03:14 AM
  5. Base Tune?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2005, 01:11 PM
