Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: 4l80e parameters to prevent TCC from disengaging in 4th gear
    Jun 2009
    Default 4l80e parameters to prevent TCC from disengaging in 4th gear
    I've recently read that HP Tuners added tables that now allow the tuner to prevent the 80e TCC from unlocking when the throttle goes to 0%. I downloaded the latest version of EFI live and quickly looked, but I don't see any new TCC tables. Any chance for EFI live to add this ability?
    Can you pm me a link to that (regarding HPT)...
    Aug 2007
    Subscribed! Any updates?
    Jun 2009
    Well, long time but here's an update. HPTuners has a new table called "minimum throttle release." Tq converter no longer unlocks at 0% TPS. This would be highly beneficial to have for those of us with EFI live.
    http://www.hptuners.com/forum/showthread.php?t=41057
    OK, thanks for posting back.
    Yes, this would be a HUGE addition for all supported PCMs (even the LS1, Id kill for a P10 update with this in it. Tell me where it is in the code and Ill build a .cax if need be.) and the T42!
    Aug 2007
    I'd be all over helping to test those T42 files!
    Thanks Guys, we can look to add it, but everyone is asking for it over many different PCM's and TCM's, it's going to take time and I'm sorry to say can't be classed as a high priority add.
    Aug 2006
    I would love to see this added. (LS1b for me)
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    +1 x2 on LS1B.
  1. trans not going into 4th gear even though log says it is?
    By SimpleManLance in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 21st, 2011, 01:25 AM
  2. 4l80e 4th gear and tcc problem (running from 4L60E segment)
    By kkustomz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 28th, 2011, 02:05 PM
  3. Need to hold 4th gear for dyno
    By samdweezel05 in forum Allison 5 & 6 Speed
    Last Post: July 1st, 2011, 01:54 PM
  4. Holding 4th gear for Dyno
    By Matt68 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 30th, 2011, 03:59 PM
  5. Keep TCC locked in 4th gear
    By FnGone in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 24th, 2008, 11:02 AM
