Results 1 to 6 of 6
Thread: Tuning Big Injectors
    Mar 2009
    Default Tuning Big Injectors
    Alright I went from 60% injectors to 100% injectors and now it is time to retune. I currently have a fuel knock that I would assume because the timing is to high from the 60% injectors. Does that sound about right I need to pull timing back to help it go off sooner with the bigger injectors. Nothing else changed on the truck.
    2002 Chevy Duramax with a few supporting mods.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    You will need to reduce timing and pulsewidth by a lot with 60% injectors.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    Lifetime Member LB72004's Avatar
    Dec 2011
    yes, the larger the injector the more the timing will need to be pulled back. who does your tuning? you can have him update your tune with the now larger injectors. if you do it yourself then you could start by subtracting about 40%. not sure on that number though
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Mar 2009
    Zach was doing my tuning. I have started to make some tunes and also went to Zach's class in IA and want to start making my own adjustments and learn more.
    Jun 2011
    A flow rate sheet for your injectors would be very helpful to you in making sense out of how much more your injectors flow than your old injectors under different circumstances. the % is typically under high pressure and duration situations.
    423-506-7427
    Mar 2009
    Zach helped me figure it out. It was pilot injection that was causing the knocking sound. I am slowly working on bringing it down to eliminate it completely if possible. I am not really sure if I should come down any more or if I should keep going until it is completely gone.
  1. HELP Tuning with no wb? 4.8 with big cam!
    By T&A Custom Rides in forum Gen III V8 Specific
    Last Post: January 26th, 2012, 10:40 PM
  2. 2000 K3500 7.4 help injectors too big
    By SS540CORVAIR in forum Vortec V6/V8 Specific
    Last Post: July 29th, 2010, 10:20 AM
  3. Big injectors??
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2007, 12:53 AM
  4. Big cams and VE tuning
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 06:27 PM
  5. help with tuning AC with big cam
    By 01blkss in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2006, 01:48 PM
