Im just trying to see if this is normal or if i need to do adjusting and were. I have my tune dialed in pretty mich right were i want it. Good smooth power some but not too much smoke. But i have the 6 speed trans in an 06. And every shift i make it lets out a little puff of smoke When clutch is released and back on the throttle. And if im lower in the rpm range and stand on it i could kill small forest creatures with the cloud i let out then its clear. I am running stock injectors and my rail pressure is mainly around stock pressures just moved around a bit indifferent areas. Im also running a silver bullet 62 turbo.Is this just something i have to live with since im loading the engine all the time and loosing all boost built up between shifts? I have pulled all the duration i can without sacraficing any power and i have adjusted up my boost fueling table and still seemto get just as mich smoke. Any insight on were i should focus on or is this just a manual trans thing. Thanks guys
