Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Can't get the crankshaft relearn done
  1. #21
    Aug 2012
    Quote Originally Posted by slows10 View Post
    There are some problems with the spreadsheet in some situations, it is not perfect for every make and model. Do you have a genuine factory service manual for your s10? Or a way to get genuine wire diagrams for your 99 s10 and a 2002 s10 if not you will have to depend on info you read to help fix your problem. Do you have your brake and clutch switch pinned correctly? Not what the spreadsheet says but what a factory diagram says?
    I will look. I just found this thread and I think this might be my problem. You just pinned 32 and 34 and grounded both wires right?
  2. #22
    May 2010
    Yes I cant remember what pin number wires i tied together. 32 34 sounds about right
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
  3. #23
    Aug 2012
    That did the trick. Thanks for the help.
  4. #24
    Ok, cool
  5. #25
    Aug 2012
    I wonder if lextech should put that in his wiring diagram regarding manual trans cars
  6. #26
    Aug 2012
    So I grounded those two pins which tells the PCM I am in park, can I just leave them grounded or is that going to make my truck run while thinking it is in park/neutral instead of in gear? Doesn't it run different values based on in gear or not?
  7. #27
    Aug 2006
    Bubba did find and error in the 99 S10 to 0411 Wiring file. It was on the bottom portion of the file. I just typed in the wrong number. It has been corrected. Grounding C1 32 and 34 during the relearn has been well covered for several years now. I get these questions all the time with the fullsize truck guys---They are too lazy to add the 4 wires for the Trans Range Switch and then want to blame someone for not being able to do the relearn. The automatic trans S trucks already have the 4 wires.
    slows10. I am not aware of any other issues with the wiring files. I have given out hundreds of them. If you know of an issue---Please let me know so that I can look into it.
    Jeff
  8. #28
    Aug 2012
    I am not blaming you at all Jeff. I appreciate the help. I just want anyone who did the same swap as I did with a manual trans to know about grounding those two. It took me three days to figure it out after many failed attempts at the relearn. I thought it was something I was doing wrong in the program. Maybe the automatic s10's have two extra wires to plug in. I had no wires left over after the swap except a 12v source wire.
    I was just thinking that maybe you could add a note on the top on the instructions. It may benefit a few people.
  9. #29
    Aug 2006
    Quote Originally Posted by bubba68ss View Post
    No, I didn't mean you. The Fullsize guys are the one who (For the most part) don't want to add the 4 wires and then can't do the relearn and want to blame someone.
    Jeff
  10. #30
    Tables for automatic trans P/N also apply to manual trans clutch disengaged (freewheeling).
  1. CASE Crankshaft Relearn with E37?
    By engimuneer in forum E37, E38 & E67 PFI ECM's
    Last Post: December 14th, 2011, 08:05 AM
  2. Custom operating systems and crankshaft relearn?
    By 94SS in forum Custom Operating Systems
    Last Post: October 10th, 2011, 01:42 PM
  3. LB7/LLY Duramax crankshaft pattern
    By GMPX in forum General (Diesel)
    Last Post: May 27th, 2009, 01:46 PM
  4. crankshaft correlation
    Last Post: May 16th, 2009, 03:04 AM
  5. Crankshaft Position Sensor Code
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2006, 04:08 PM
