Results 1 to 9 of 9
Thread: Unexplained lope at idle. Fuel Pressure Reg?
    Nov 2011
    Default Unexplained lope at idle. Fuel Pressure Reg?
    I have a very bad lope at an idle and the pulse width is set at stock levels in the idle cells? Maybe the problem is mechanical? Pressure regulator maybe? It just seemed to happen out of nowhere. Here is a log and the tune I was running. It gets really bad in the last part of the log when its idling.
    Lopey idle after P0191.efiJoes LBZ DSP5 Max Effort.tun
    Mar 2009
    Does this truck have a EGR blocker plate installed? I always leave it enabled, but set the parameters so that they will never be met. Others have had issues with completely disabling simliar to what your having.
    Lifetime Member LB72004's Avatar
    Dec 2011
    can you command max psi and get it? will the pressure regulator respond to DVT pressure commands?
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Mar 2009
    Also can you post a log of it at idle while it is loping with no throttle changes and it stopped? In your log I noticed you were driving and constantly changing throttle input which made it a little difficult to keep track of desired VS actual fuel pressure as desired was changing everytime you hit the throttle.
    Nov 2011
    Quote Originally Posted by THEFERMANATOR View Post
    EGR deleted and exhaust stock otherwise sorry about no signature. Look from the 700th frame on to the end its stopped loping with no throttle.
    Mar 2009
    Try setting teh lower portion of your pedal position to desired torque back to stock and see if it still does it. Also does it do it in neutral or only in drive? If you watch the log compared to your tune file, you can see it jumping around considerably for rail pressure and pulsewidth. Desired and actual are pretty close to each other, so it doesn't look like a fuel pressure regulator issue to me.
    Nov 2011
    It does it in neutral seems to quit in gear. Also it does it across all of my tunes. Thanks for the input
    Mar 2009
    Try setting it so that your throttle based torque and torque tables are stock in the idle areas as well, or better yet try a stock tune to see if it is the tune or not.
    Nov 2011
    Yeah I thought I should try flashing in a stock tune also. Didn't work though same problem but when I was making the log I noticed that my rail pressure gauge was fluctuating about 1k psi and it was reading 3k below what the log said so I decided to unplug the gauge and try that and boom runs fine. My EGT gauge has been acting funny since I installed them so I assumed I may have some grounding issues. Have you ever heard of that happening at all? Again thanks for the input and fast responses.
    Joe.
  1. LBZ Fuel Pressure Reg. on LB7
    By xploitdiesel in forum Duramax LB7
    Last Post: July 8th, 2012, 11:48 AM
  2. can I log fuel pressure with my glowShift fuel pressure gauge?
    By ryans1000 in forum External A/D inputs
    Last Post: August 16th, 2011, 01:35 AM
  3. lope idle
    By MARC75 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 2nd, 2010, 02:49 PM
  4. Lope at Idle
    By tdfchevy in forum Duramax LB7
    Last Post: February 28th, 2009, 07:47 PM
  5. lope idle?
    By FH Leader in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 18th, 2009, 11:15 AM
