Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Bbx and pids
    Mar 2007
    Not sure whats happening but its not there
Name:	S AND T.jpg
    May 2008
    Do you have the LS1B_A highlighted (Not just checked) on the left side?
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Feb 2012
    I think nevinsb has it.
    Those pids in the right are all E38/E40/E67 pids, and the EQSPK_M pid you have loaded is a E38 only pid.
    As nevinsb said, DYNAIRTMP_M is a LS1B only pid, and then it is defined for only some LS1B OS's...
    you pic shows the E38 pidlist highlighted in the blue section in the upper left.
    Mar 2007
    OK now Im getting somewhere. the only other one that I want is oil pressure but its not in the list (sensor volts is) thanks by the way
    Feb 2012
    There isn't a direct oil pressure pid in LS1.
    You can olny log EOPS, pressure is calcualted pid form voltage and can be displayed in v7 via CALC.OILP_LS1
    Mar 2007
    Thanks thats what I thought. I have selected the pids that i want and programed them into V2 but when I go to read from v2 the pid selection is changed is that correct?
    Is there a reason that you need to highlight the selected pid as well as have the box ticked ?
    You don't need to checkmark the box...
    you make sure the pid appears in the green section while one particular pid list is highlighted in the blue section...
    when you have all the pids you want, and the bar graph shows no red at the bottom of the green section, then click Save, and then Program All (accesses via the downarrow next to Program).
  9. #19
    Which pids are being changed...?
  10. #20
    Mar 2007
    I think I see where I have been getting confused...when you read V2 you still need to highlight the pid list you need to view, I thought it would automatically open the one I had just saved
  1. P12 BBx functions...
    By ScarabEpic22 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 11th, 2014, 01:18 PM
  2. 06 duramax bbx help
    By rodder55 in forum Black Box Logging
    Last Post: June 12th, 2012, 09:49 PM
  3. BBx troubles
    By jollyrogr in forum Diesel
    Last Post: August 8th, 2011, 05:09 AM
  4. new v2 starting from bbx 0024
    By restless@westnet.com.au in forum General
    Last Post: May 24th, 2011, 11:26 AM
  5. BBx Cal Flash?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 16th, 2011, 11:20 AM
