Results 1 to 10 of 20
Thread: Bbx and pids
    Mar 2007
    Default Bbx and pids
    I have been reading how to load pids in to V2 and am getting confused, I have loaded the pids from the list in S&T and can log them OK, but some of the ones like injector duty cycle are not there. How do I add pids from V7? into V2 I am only talking about LS1B
    The LS1B injector pids are GM.IBPW1 and GM.IBPW2.
    The pids CALC.INJDC1 and CALC.INJDC2 can be applied to the log afterwards.
    Make sure V8 is at build 203 and V2 firmware is at 2.07.35, and that you do Program All (accessed via the down-arrow next to Program).
    Mar 2007
    Thanks joecar that worked
    Mar 2007
    Im trying to Log Grams/cylinder GM.DYNCYLAIR_DMA but cannot find it to put in V2 what should I be doing?
    Lifetime Member darcy's Avatar
    Feb 2012
    DYNCYLAIR_M is the PID in v8
    +1 that is correct (the _DMA pids are suffixed to _M for BBL).
    Mar 2007
    I dont seem to have that pid in S&T under LS1B
    Do you have V8 build 203 installed...?
    In the yellow section on the right, click on the column heading that is the pid name (this sorts alphabetically) and scroll down, you should see it.
    Mar 2007
    yes build 203. I even searched with its name in the key words
    May 2008
    Should be there. Don't think there's a requirement for other pids to be selected either.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  1. P12 BBx functions...
    By ScarabEpic22 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 11th, 2014, 12:18 PM
  2. 06 duramax bbx help
    By rodder55 in forum Black Box Logging
    Last Post: June 12th, 2012, 08:49 PM
  3. BBx troubles
    By jollyrogr in forum Diesel
    Last Post: August 8th, 2011, 04:09 AM
  4. new v2 starting from bbx 0024
    By restless@westnet.com.au in forum General
    Last Post: May 24th, 2011, 10:26 AM
  5. BBx Cal Flash?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 16th, 2011, 10:20 AM
