Hi guys,
ok this is actually more of a mechanical question....i think....
The log attached show my car lean only through first at 4K and above....the car has only just started doing this...ie you can see in 2nd and 3rd that the ben is close to 1 and afr if roughly as commanded.
When commanding 12.3 as here it is worse and really leans out
when I commanded 12.6 it was only about 14:1 in the lean it is consistently lean, if I stamp on it in 2nd it will do the same
Are my injectors done ? They are maxing out too, so I have some on order but really want to know if this is the issue or could it be more sinister??
log_tune0006_race7.efi
PS yeah I am hitting the limiter in the log....the gearbox was on its final legs, nice and dark fuild came out...new one in now with 3200 stall
