Results 1 to 7 of 7
Thread: Engine stalling at idle in open loop only
    Sep 2012
    Default Engine stalling at idle in open loop only
    Hey everyone,
    I have just signed up and wondered if anyone could help out. I have just tuned a car which is a WH statesman cam only with a 224 232@112LSA. The car has the stock throttle body and it idles fine except when you first start the car up and the car is in gear and stationary and you apply the power steering. The engine will die if you are in gear only and you apply the power steering while stationary. It wont do it when in neutral and it will only do it when in open loop. As soon as the car goes in closed loop, the idle is rock solid and it doesnt die no matter what you are doing with the power steering.
    Is there a simple way around this as I really havent had any cam experience.
    Thanks in advance.
    Oct 2006
    Have you carried out a RAFIG and RAFPN scan to set your desired air flow?
    Sep 2012
    Quote Originally Posted by rally1 View Post
    hi mate. I haven't done either of those. I've never had to before. Is there a tutorial available for carrying them out?
    Sep 2008
    Quote Originally Posted by genR8 View Post
    RAFIG / RAFPN turotials can be found ont he forum - take a look at the idle-specific threads for links to them all.
    HSV Senator 300 - the Classy C4B...
    C4B - ETP215s 62cc, Comp 215/223 .601/.609 @111+3, Manley 8.050" 5/16" P/R, Morel Link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster chain, OTRCAI, T-56 - RipShift, HydraTrak 3.91:1, DiFilippo 1.75" 4-1s, twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune.
    308rwkW(413rwhp)
    Oct 2006
    Its a must do when you have fitted a cam, read the forums and fully understand how and why it works as its a major factor in getting a good idle... you will also need to redo it any time you make major changes to the idle like timing and desired idle.
    Sep 2012
    Thanks heaps for the leads guys. I will have a good look at some of the threads.
  1. Closed Loop Idle v Open Loop Idle timer
    By Hooter in forum Gen III V8 Specific
    Last Post: May 28th, 2012, 03:10 PM
  2. E67 Open Loop Idle?
    By JAY4SPEED in forum E37, E38 & E67 PFI ECM's
    Last Post: January 28th, 2011, 04:22 AM
  3. Force open loop just at idle
    By RonSS in forum Gen III V8 Specific
    Last Post: December 30th, 2006, 12:59 PM
  4. Truck wont idle during open loop speed density
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2006, 06:43 AM
  5. Strangeness with open loop idle lean limit (B3607)
    By turboberserker in forum Custom Operating Systems
    Last Post: February 18th, 2006, 11:14 AM
