Results 1 to 5 of 5
Thread: '08 LLT controlled by new ECM?
    May 2010
    Default '08 LLT controlled by new ECM?
    Has anyone explored this option?
    I have low mileage '08 SIDI 3.6L LLT from a CTS that I would love to be able to tune and put in as a stand-alone application. It has the Bosch ECM now. Would it be possible to wire the existing harness into one of the new ECM computers to allow control and tuning of this engine with EFILive?
    If not, any ideas on making it a stand alone. I do have the body module if that helps.
    Thanks!
    Dave
    Hi Dave, we don't have any plans to support this ECM, however, I think Trifecta are the only ones out there able to program that ECM for a stand alone application, you might want to check with them.
    May 2010
    Thanks for the reply GMPX. I may go that route with Trifecta as it would probably be easiest.
    I was just curious if it would be possible to merge the '08 harness into one of the new EFILive supported SIDI computers and tune from there.
    May 2010
    Something like an E39 ECM re-pinned to the LLT and start with the closest base program, go from there.
    I don't know if the engine hardware is the same between the two, the high pressure pump, injectors etc might be different.
  1. New ECM ? Have question bout vin license an efi live to new ECM
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:19 AM
  2. Can the 1-4 shift light be controlled on the e38s like the 0411 PCM?
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: March 10th, 2011, 01:33 PM
  3. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
  4. Replies: 28
    Last Post: December 23rd, 2008, 02:22 AM
  5. Using the pcm controlled shift light
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2008, 05:56 AM
