Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: V1 user
    Senior Member DocZ28's Avatar
    Mar 2007
    Default V1 user
    Hi I'm a V1 user, and I'm having problems to connect into a PCM
    I just upgrade the software. And I can not connect to any pcm to scan or tune. I only can read my car.
    In the past I did not have this problem, I have 9 pcm licenced to my cable.
    Two days ago I purchase a licence and start to tune a LS1B Pcm, Now I don even can scan the car. But if I read my car, ther is no problem.
    What can I do?
    Which V7 software build version do you have installed (go Help->About)...?
    Can you post some screenshots...?
    Mar 2007
    Version V7.5.7 (Build 211)
    Licence Commercial Scan and Tune
    Mar 2007
ID:	13855Click image for larger version.
ID:	13856Click image for larger version.
ID:	13857Click image for larger version.
ID:	13858Click image for larger version.
    Mar 2007
    You cannot have both the Scan tool and Tune tool connected to the PCM at the same time (ie, you need to disconnect from the PCM in the Scan tool in order for the Tune tool to work). Try closing the Scan tool and flashing again.
    Mar 2007
    The problem is that the cable is only working in my car's pcm I can tune and scan.
    But in other pcm it can't be connected. Drops this error. And they are already licenced to my cable.
    The other car has a ALDL connector wiring problem...?
    Mar 2007
    No no problem at all.
    I notice this few day ago when I couldnĀ“t read 2 1998 Ls1 PCM, I think that was for the software update
    Cuz Last Sunday I purchase a licence, download the file of an 2000 LS1, made some changes and upload the file and monitor with the scan. But this monday I could not connect any more.
    But as I tell before with my car I have not any problem, is also a 2000 Ls1 camaro.
    Could it be due to a configuration?
    Please try using the V8 software to read/flash your PCM.
    Sorry my mistake, I didn't realize you had a V1 interface.
    So in that case, please supply the appropriate *.blx trace files as described in this web page:
    http://support.efilive.com/kb_articl...8254-QOGC-9586
  1. Please Help a New User
    By Tuned55 in forum General
    Last Post: September 19th, 2010, 02:06 PM
  2. New user
    By VACARELLAB in forum Duramax LB7
    Last Post: April 4th, 2009, 03:39 PM
  3. User installation
    By BackinBlack02SS in forum FlashScan V2
    Last Post: November 26th, 2008, 09:41 AM
  4. New user needs help
    By LowETz in forum General (Petrol, Gas, Ethanol)
    Last Post: May 4th, 2007, 01:39 PM
  5. New user with questions.
    By turbolou in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2005, 12:28 AM
