Results 11 to 20 of 23
Thread: V1 user
    Senior Member DocZ28's Avatar
    Mar 2007
    Please try using the V8 software to read/flash your PCM.
    Sorry my mistake, I didn't realize you had a V1 interface.
    So in that case, please supply the appropriate *.blx trace files as described in this web page:
    http://support.efilive.com/kb_articl...8254-QOGC-9586
    This is the only one that is from yesterday
    Sorry I can add in attachment
    Quote Originally Posted by DocZ28 View Post
    Email the trace files to me at paul@efilive.com
    Mar 2007
    Copy that. BTW I install the software in other laptop, and when I connect the cable an into the car a window came up saying somthing about that the cable was for an older version software some thing like that.
    Will send you the files later.
    thanks Paul
    Is your V1 firmware version 2.4.72...?
    Mar 2007
    Joe this is what is displayed when I try to connect
    20:00:18.998: EFILive V7 Version V7.3.3 (Build 475)
    20:01:51.178: Ready.
    20:02:07.668: Scanning for EFILive FlashScan V1 USB
    20:02:07.683: Autodetect interface ...
    20:02:07.730: Connection to [FSP] interface is OK
    20:02:07.730: Autodetect PCM...
    20:02:07.870: Autodetect ECM...
    20:02:08.011: Autodetect TCM...
    20:02:08.182: Interface firmware model: FSP
    20:02:08.198: Interface firmware version: 1.2.17
    20:02:08.229: Interface firmware date: Jan 18, 2005
    20:02:08.260: FlashScan serial number: 003597051511
    20:02:08.401: Initialising PIDs...
    20:02:08.510: Initialising Modules...
    20:02:08.510: Ready.
    20:02:26.528: Disconnecting ...
    20:02:26.544: Disconnected
    Mar 2007
    Is there a wey that the cable can be locked to use in only one pcm?
    The trace shows that the PCM is not responding to any commands sent to it by the FlashScan V1 device.
    That can because by:
    1. a blown cigarette lighter fuse (does FlashScan power up when connected to the OBDII connector?)
    2. faulty PCM or OBDII connector (can the scan tool software log data from the PCM?)
    Mar 2007
    Not I can not log any data either. but it is kind a rare 3 different cars.
    Rigth now I'm changin the pcm to my car and will test it.
    Let you kow what happen
  9. #19
    Are you saying that the V1 device will not connect to 3 different cars? If so, then that kind of indicates a problem with the V1.
    Does the V1 work on any vehicles anymore?
    Does the V1 power up when connected to a vehicle?
  10. #20
    Mar 2007
    It works on my camaro, and the pcm of that other car also works, so there is a problem with the obdII port or wiring.
    I will check for the other 2 98 camaros
    Thanks for the help
  1. Please Help a New User
    By Tuned55 in forum General
    Last Post: September 19th, 2010, 03:06 PM
  2. New user
    By VACARELLAB in forum Duramax LB7
    Last Post: April 4th, 2009, 04:39 PM
  3. User installation
    By BackinBlack02SS in forum FlashScan V2
    Last Post: November 26th, 2008, 10:41 AM
  4. New user needs help
    By LowETz in forum General (Petrol, Gas, Ethanol)
    Last Post: May 4th, 2007, 02:39 PM
  5. New user with questions.
    By turbolou in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2005, 01:28 AM
