Same issues as here http://forum.efilive.com/showthread....ke-Symptom-GTO
except 99 silverado, cos 5 5.3l speed density, failed maf hitting a wall at 4600 where it seems to be soft limiting the spark, rpm still climbs but power holds dead flat. No maf installed on vehicle, blow through carb so it is not able to pull fuel.
