Results 1 to 7 of 7
Thread: High idle???
Hybrid View
    Feb 2012
    Default High idle???
    Hey all just wondering if you guys and gals that are running EFI Live are still able to use your high idle function? Mine worked for about a week then stopped? I took it into the dealer to see if it was turned off because of the reflash and they said nope. There computer said it's still programmed. Glad the dealer still works with me and my deleted truck and warranty. Do you guys and gals have any idea's why it isn't working even though it's still activated? With winter coming around the corner fast I could sure use this function again as it sure helps to warm her up, up here in Canada.
    Thanks for you help all
    Cheers Dougal.
    Member Motorzane's Avatar
    Jun 2011
    Check and see if you have a brake switch problem or the Emergancy brake circuit issue. Does you brake light come on when you push on the Emergancy brake
    Feb 2012
    I went out and checked my E-brake and the light comes on and I even put in my stock tune like a couple of guys on cummins forum said and no joy? Don't know what else to try?
    Feb 2012
    Thanks for?????
    Jun 2011
    Does the cruise control work at all? If the high idle is turned on, then something is not happy to let it work properly. Any aftermarket remote start or radio/tv?
    Feb 2012
    Yep the cruise works fine. No remote start or radio/tv. This is just my luck.
    Aug 2011
    If i were you i would let dealer reflash ecm and the tipm and reset high idle .
    Tuning by Zack StarLite diesel
  1. high idle help
    By amiller406 in forum Duramax LB7
    Last Post: March 25th, 2011, 07:55 AM
  2. tune help, very high idle
    By BROKE in forum Gen III V8 Specific
    Last Post: September 15th, 2008, 07:07 AM
  3. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 04:14 PM
  4. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 02:18 PM
