Just finishing up a 24X conversion on my 89 Camaro and I still have the 700R4 transmission in the car. I still have the TV cable hooked up to the 700R4, so I know it will shift, I just don't have the torque convertor lock up capability anymore which is ok for now. The wiring harness has the connector for the 4L60E transmission which I will install later on. I have installed a tune file into the ECM for a 2002 Camaro with an automatic transmission. My question is what programming changes will I have to make to run with the 700R4 when the program is expecting a 4L60E. I'm thinking that the car will run, but that I'll be setting lots of codes.
