Results 1 to 10 of 18
Thread: Reading Lambda on LM-2 when Stoichiometric is 14.2 in tune
    May 2012
    Default Reading Lambda on LM-2 when Stoichiometric is 14.2 in tune
    I'm working on getting myself educated to start using my LM-2 and I know my {B3671} Stoichiometric AFR is set at 14.2 (Nothing but +/- E10 here)
    The LM-2 is factory set to show Stoich of 14.7 and if I want to read Stoich in my setup I would need to change the LM-2 to other Volt readings from what I gather. Is reading Lambda the same way? or when you read lambda it does not matter?
    In searching there is a ton on information on the LC1, but I cant seem to find the correct correlation to the LM-2
    Thanks in advance,
    John-
    Yes, correct, Lambda is the same regardless of fuel used.
    To see Lambda in the scantool, the pid CALC.AFR_LM11 has to be divided by 14.7 (which is the stoich AFR value setup in the LM-1).
    May 2012
    Joe,
    Ok, so this file
    "{CALC.AFR_LM11.AFR}/{GM.AFR}"
    Should be changed to read: "{CALC.AFR_LM11.AFR}/{14.7}" or "{CALC.AFR_LM11.AFR}/{GM.AFR}/{14.7}" ???
    and then copied an inserted into the calc_pids.txt file??
    From the old tutorial I'm not to modify the sae file, just obtain the pid information from there correct?
    Sorry for to question - This is my first edited pid.......
    john-
    The measured Lambda is: "{CALC.AFR_LM11.AFR}/{14.7}"
    The BEN correction is: ""{GM.EQIVRATIO}*{CALC.AFR_LM11.AFR}/{14.7}"
    the problems with that are these:
    - LM-1 has a programmable stoich AFR which is usually (but not always) 14.7,
    - GM.AFR depends on the value of B3601 (which can be set to other than 14.7),
    this is why GM.EQIVRATIO is used (it is 1/lambda).
    That is incorrect, it would have to be this (assuming B3610 is set to 14.2 for E10):
    "{CALC.AFR_LM11.AFR}/{GM.AFR}/14.7*14.2"
    but by using GM.EQIVRATIO you can reduce that to this:
    Quote Originally Posted by Protec View Post
    Hi John,
    DO you have FlashScan V1 or V2...?
    Do you have the serial comms (null modem) cable connecting your LM-1 to your V2...?
    May 2012
    Joe,
    Very much appreciate the information.
    I'm using V2 and I made the serial cable that connects the LM-2 to the V2..... Its an LM-2...
    Let me know if you need anything else.
    Best,
    John~
    May 2012
    Joe,
    I don't have B3601 rather B3671 (Stoichiometric AFR) and its set to 14.20
    Joe,
    John,
    With the serial comms wideband input into V2, you can simply use the calc_pids.txt from the Calc.VET tutorial...
    you would use the pid CALC.WO2BEN for pure wideband tuning
    ( you would use CALC.SELBEN for mixed wideband/LTFT tuning )
  1. Old School Approach, tune for best (lowest) MAP reading?
    By Mr. P. in forum Tuning For Economy
    Last Post: June 1st, 2011, 04:32 AM
  2. Reading an HPT tune
    By 68problemchild in forum General
    Last Post: December 24th, 2010, 11:33 AM
  3. Reading an HP tune
    By 68problemchild in forum Gen IV V8 Specific
    Last Post: November 13th, 2010, 12:06 PM
  4. Replies: 3
    Last Post: August 27th, 2010, 03:24 AM
  5. No VIN when reading PCM w/ tune tool!!
    By sean3393 in forum Vortec V6/V8 Specific
    Last Post: February 5th, 2008, 11:19 AM
