Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Trans Segment Swap?
Hybrid View
    Jul 2012
    Well, the OS do not match. I took the 2002 5.3 Silverado tune from TFD and copied in the 2002 Camaro Trans segment info. They are both the 12212156 OS. My 2001 5.3 that I am actually working with is 12212156 (looks like it was only used in 2001 Silverado???). I have the commercial Scan&Tune so I should be able to flash the new OS on to the PCM, right? The icon is grayed out in my tuning software so I can't. Am I missing something?
Name:	5.3 Capture.JPG
    Quote Originally Posted by LS-SWAPPER View Post
    Well, that narrows it down to 12212156 then.
    Yes you should be able to full flash (to change OS)... FlashScan has to be plugged into your PCM, and your V7 software has to be registered
    (go Help->About, if you see Demo mentioned then you have to enter the blue card details).
    Jul 2012
    Darn, that was a typo. The 2002 OS from the truck and camaro that I downloaded from the web are both 12212156, but the OS of the 2001 PCM I actually have in my hands is 12208322. 12208322 is the one that seems to be only used on 2001 4.8, 5.3, 6.0 and 8.1 and nothing else.
    Regardless of that, I should be able to change the OS by performaing a full flash. Not sure what's going on there. My software is registered with all the blue card details and it is labeled as "commercial". I will have to look into that further. Thanks again Joecar.
    Jul 2012
    Yay Me! I took the 2002 Truck 5.3 OS (12212156) and put in the 2002 F body manual trans segment. When I reconnected everything the option was there to perform a full flash, so I did. Everything seems to work great! The engine fired right up and is running on my engine dyno right now using the stock tune. Thanks Joecar!
    Hey cool thanks for posting back your result.
  1. How do you do a segment swap?
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2012, 08:18 AM
  2. Can't find info on trans segment swaps
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2011, 02:19 AM
  3. 4l80e segment swap!!!
    By hyderm87 in forum Custom Operating Systems
    Last Post: May 12th, 2009, 03:29 AM
  4. A4 to M6 segment swap help
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2009, 10:24 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 07:14 PM
