Results 1 to 5 of 5
Thread: Can someone explain why the '01 and '02 ls1s are better?
    New Member The_Alchemist's Avatar
    Default Can someone explain why the '01 and '02 ls1s are better?
    I was discussing the differences etc of efi live with another member and he mentioned that EFI live will allow me to switch my operating system over to the '01/'02 model years (I'm a 2000) which he said was easier/better to tune.
    Can someone please elaborate for me the differences, advantages and reasoning behind this. My tuning knowledge is limited to a brief view of ls1 edit 2-3 years ago, so I'm not exactly up to speed on the evolution of tuning ls1s.
    Thanks a bunch and I look forward to ordering my EFI live flashscan as soon as it's available to us common folk.
    Aug 2005
    Alot of people (including me) ungrade the OS to a 01+ system for ease of tuning.. there is no secondary VE table to mess with for one..Also, there are many options in the custom OS' but they are only avalible for 01+ systems.
    For example: Boost VE table, IAT VE multiplier, ability to run dual spark (high and low octane tables) in SD mode, Valet mode, controlling any given AFR in table 3647... the list goes on.
    You would need the commerical version of Flashscan to use these things though.
    1992 Turbo LSX Notchback Mustang 275 radial car - under construction
    2008 Sierra 2500HD Duramax
    i want to make sure i understand this. If i want to change to a new operating system. I need to change the ecm and wiring harness. by the way i hav a 98 ecm.
    Jan 2005
    for the '98's you will have to upgrade your pcm to a 99-02. It's a bit more involved than just swaping pcm's though.
    can you elaborate on that?
  1. please explain
    By HINDZY in forum Custom Operating Systems
    Last Post: July 22nd, 2008, 03:08 AM
  2. Can someone explain to me......
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 29th, 2007, 05:41 PM
  3. Can someone explain what..
    By trymyz in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 02:58 PM
  4. Tuning VZ LS1s any issues?
    Last Post: June 1st, 2006, 12:01 AM
