How to avoid backfire when tuning a nitrous car ?
what tips could i do ?
EFILive Tuner
If you have correctly setup window switch, you shouldn't have a problem. Also, avoid overly rich mixtures - tune by plugs - you can use the wideband as a guide, but it is not the end-all when on the jug...
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
what do you mean by tune by plugs
do you mean to check the plugs after each run ?
EFILive Tuner
Yes, shut the engine down at WOT and inspect the plugs for fuel ring/timing mark. Pull the car back to the pits or swap some plugs on the return road - don't drive back to the pits as that will ruin the readings... It is the only way to accurately tune nitrous cars.
GM EFI Tuner
